Old 11th November 2002, 02:57 AM   #1
Arrow amp required
Hi there from New Zealand. I'm looking for a simple solid state design of about 150-200 WRMS. I am needing to build 2 of these for stereo into a 2U rack case. Probably need to use torroidal trans. for space contraints. Is to be used to drive foldback wedges in P.A. app. Any direction appreciated.
Bryce Turner
Old 12th November 2002, 05:36 PM   #2
good reference and very popular among the DIYers: www.sound.au.com/projects.htm
best regards,
HB.
Old 12th November 2002, 06:21 PM   #3
halojoy is offline halojoy  Sweden
On Hiatus
Default 2 good starting points
http://www.discovercircuits.com/A/a-audioamp.htm
http://links.epanorama.net/links/audiocircuits.html
Also hugobross link is VERY good
Old 13th November 2002, 12:26 AM   #4
Default thanks
many thanks for your suggestions. I think I have settled on a design to try. Will let you know how it goes. I am going to need to learn a little more about transformers i.e. torroidal vs laminated etc, before finishing the power supply.
Again, thanks,
BT
Old 13th November 2002, 12:37 AM   #5
On Hiatus
Default Re: thanks
Again, thanks,
BT
Almost everyone sells/uses torroidial trafos nowadays.
But if you can find some laminated trafos
they will work just as fine!
In old thrown away electrics, there can be real good old trafos
almost for FREE.
You can need a shield between the trafo and amp,
if the input of amp is near to trafo.
But that is mostly not the case.
help required with p3a Mark25 Solid State 5 15th November 2006 11:41 PM
help required! ross1976 Analogue Source 0 15th December 2004 10:28 PM
Help required ! LarryN Parts 2 19th July 2004 01:05 AM
Help required martioz Swap Meet 3 2nd February 2003 03:42 AM
Help required please Andy G Multi-Way 0 29th November 2002 10:50 PM
Page generated in 0.07917 seconds (75.34% PHP - 24.66% MySQL) with 10 queries
