Old 1st March 2006, 03:39 AM   #1
Send a message via MSN to ANALOG GUY
Default J-FET Question...?!?
I searched many forums about parts for design preamp / riaa / poweramp, why most of people suggested me only J-FET, why didn't Vacuum Tube ?
Does many J-FET project of PASS & Solid state better-stability more than TUBE ?, Yes or No.
If money not problem for DIY, Which parts do you want to build your audio project ?
Regard
analog guy
Old 1st March 2006, 03:55 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi ANALOG GUY,
Tubes are alive and well. Check out the tubes forum. There are some under developement and several already built and tested.
For low noise applications, solid state parts have an advantage. That is why you will get more suggestions that way.
I have both. I like both. Start digging and building!
-Chris
Old 2nd March 2006, 09:46 AM   #3
Miles Prower's Avatar
Default Re: J-FET Question...?!?
Regard
analog guy
A major reason for that is due to the square law input characteristic of the JFET. It gives less harmonics, and harmonics that roll off with frequency faster than the 1.5 law of VTs, which, in turn, is better than the exponential input of BJTs. Stability really doesn't have anything to do with it since the gains of VTs and JFETs are comparable.
There are no foxes in atheistholes
www.dolphin-hsl.com
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.06207 seconds (70.73% PHP - 29.27% MySQL) with 10 queries
