I'm curious, I've noticed my Leach Amp causes a fairly large (about +4VDC?) "thump" when I turn it on. It's definately audible. Also, about 10 seconds after I turn it off I get a "suck" where it causes the drivers it's connected to to pull inward and vibrate a little bit. The "suck" isn't as large as the turn on "thump". Any idea what generally causes this sort of problem? Thanks in advance =).
#2 |
Howdy m0tion,
Most likely there are no "bleeder" resistors in your power supply. Take a read of Dejan V. Veselinovic's treatise on power supplies here: http://zero-distortion.com/start.htm under the heading Designing your own power supply … with some practical examples to learn about this arcane subject.
Two people can keep a secret if one of them is dead. |
#3 |
Well,if it is a toroidal transformer,big thump is normal.
#4 |
You're right, I'm not using bleeder resistors on the PS caps. Also, I am using a toroidal transformer. Is this fixable? I'd like to be able to use this amp in an active xover situation and without a crossover to protect the drivers from DC ...
#5 |
The Leach amp should not have a turn-on thump. From the FAQ on his web site:
Why didn't you use current source tail supplies for the diff amps? I had intended to use current sources in the beginning. However, when I started laying out the circuit board, I found that they added a great deal of complexity to an already dense part of the board layout. Therefore, I opted for resistive supplies to simplify the layout. I never had any problems with the resistive supplies. The amp seemed to work perfectly with them. An additional bonus is that the matching of the tail currents in the two diff amps is not a function of the matching of transistor parameters. The turn-on characteristics of the diff amps determine the turn-on characteristics of the amplifier. With resistive tail supplies, the diff amps turn on very gracefully at a rate set by the RC time constants in the tail supply circuits. This leads to a thump free turn on, eliminating the need for output relays to protect the speakers. If transistor current source tail supplies were used, the current source transistors tend to turn on abruptly as the power supply voltages come up, which can produce thumps in the loudspeaker. This problem is even worse if one tail supply transistor turns on before the other. |
#6 |
Yes it is fixable. I have a Leach SuperAmp with a 80-0-80 15A torroid that makes not one bit of turn on or off noise, thumping etc.
Mr. Veselinovic explains proper use and the math of how to remedy this situation for you. Give it a read. With all due respect Mr. Leolabs, "if it is a toroidal transformer,big thump is normal." only if you fail to implement proper "bleeder" resistors across the caps on the power supply, Leach amp or no. Let's not propogate old wives tales as fact, please. Mr. pooge is also right on with info from the Leach web site. Re-read all the web site http://users.ece.gatech.edu/~mleach/lowtim/ for more detail about "protect the drivers from DC" and other catastrophic failures that simply do not occur with this amp if built following the construction details. Regards
| Moscode 600 hum/turn off thump | MattV | Tubes / Valves | 17 | 9th July 2011 09:13 AM |
| Transformer hum on leach amp, turn on / off thump | wigginjs | Solid State | 9 | 19th August 2008 12:06 PM |
| turn off thump | jayme | Tubes / Valves | 6 | 23rd September 2007 07:40 PM |
| Zen amp turn-on thump | robertpear | Pass Labs | 5 | 5th January 2001 12:23 AM |
| Zen amp turn-on thump. | vdi_nenna | Pass Labs | 2 | 22nd October 2000 07:27 PM |
| Page generated in 0.09012 seconds (75.23% PHP - 24.77% MySQL) with 10 queries |
