Old 28th February 2006, 09:51 AM   #1
Question Differential output phono stage PCB
The circuit is a differential output stage using 2 2sk389, based in the Pass Pearl. It should be connected after the passive RIAA stage. I plan to put the board stacked on top of the Pearl board.
The board I am working is attached below. Please keep in mind that this is my first pcb design. I would appreciate the guidance of someone more expert.
Note that I already posted more details in this thread at the pass labs forum, but I didn't get many answers.
Old 28th February 2006, 09:57 AM   #2
An easier view ...
Old 28th February 2006, 02:02 PM   #3
And here the schematic...
Old 28th February 2006, 05:14 PM   #4
Ultima Thule's Avatar
Look at Q6 in your schematic!
Cheers Michael
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears"
Michael 29th January 2010
Old 28th February 2006, 05:42 PM   #5
Oops! Q6 should go the other way around.
The filters for both rails were initially part of a different schematic. I made a mistake when I moved it here. I will update both this mistake and the one for the negative rail which is absent.
Michael, thanks for warning.
Xavier
Old 28th February 2006, 06:02 PM   #6
Actually it may be so that you wouldn't ever notice it in a real circuit as BJT's works also backwards!
Cheers Michael
Old 28th February 2006, 06:26 PM   #7
OK. Here it is the updated schematic. I should update Q6 and Q9 in the layout, but I will wait until I have more things to correct to produce a new version.
Any comments on the layout?
Differential output stage: cap voltage? Klimon Tubes / Valves 2 23rd May 2009 11:44 PM
Will this work as a differential stage? martyh Tubes / Valves 4 9th February 2009 07:54 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Pearl Phono stage output matching? Gregorio Analogue Source 1 30th June 2004 02:06 PM
Page generated in 0.08841 seconds (72.45% PHP - 27.55% MySQL) with 11 queries
