N-channel layout question N-channel layout question - diyAudio
Old 10th November 2002, 09:29 PM   #1
JBL is offline JBL  Canada
JBL's Avatar
Send a message via ICQ to JBL
Default N-channel layout question
In anthony N-channel amp does the phase splitter transitor(Q13) need to be mounted on the same heatsink as the output device?
The schematic can be found at:
http://www.aussieamplifiers.com/download.htm
Jonathan Blanchard (J.Bl.)
---Nothing is impossible---
Old 10th November 2002, 09:35 PM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
http://www.diyaudio.com/forums/showt...5&pagenumber=4
you shuold read up on this part to understand you posted question
and yes yuo do have to have it mounted to the heat sink. if you dont youll have a nice blown board like in the pic in the link above
Old 10th November 2002, 09:36 PM   #3
halojoy is offline halojoy  Sweden
On Hiatus
Default Q13 on heatzink?
No, It would not need to be.
Actually it is best to use a separate cooler.
This transistor does not control the idle current.
That is up to what I can understand.
Maybe I am right after all.
Old 10th November 2002, 09:47 PM   #4
JBL's Avatar
hmm JasonL I think that you mix it with the thermal sensing transistor.
I'm talking about the phase splitter wich is nowhere talked about mounting it to the main heatsink(it is mounted on the main heatsink with the original pcb for anthony)
I just want to be sure.
N-channel layout questionHide this!Advertise here!
Wiring / Layout question kacernator Tubes / Valves 4 23rd January 2009 06:29 AM
ZV5 PS layout question seventenths Pass Labs 3 24th May 2008 08:08 PM
Check my layout pls. for proper grounding (6 channel opamp pre) Groundloops Solid State 9 17th February 2008 08:35 PM
Layout question for AK4396 Dac Radian Digital Source 4 25th December 2007 11:20 AM
5 channel lm3875 layout bjefferys Chip Amps 2 23rd March 2005 09:21 PM
Copyright ©1999-2017 diyAudio
