Heres me first attempt at an amp..
2 SC480 modules 1 Speaker protector module 2 Power supply modules 1 300VA 30V Toroidal In 19 inch rack case 50WRMS x 2 into 8ohm Wiring needs to be tidied and thermal protection added, otherwise its finished.. To my ear sounds pretty good.. Dion. |
#2 |
That's a nice looking unit you have there. I have to admit the rack cases look good as well, and they are easy to work with as most have aluminium front and rear panels.
Nice work, keep it up. Cheers Daz
#3 |
I see you've used a 30V transformer here, rather than the 28V specified.
I've been considering the same thing... Have you had any issues with it, such as overheating etc? Were any modifications required to make it work? Thanks! - Peter |
#4 |
Yes, thats right. I made no modifications. Originally I had 60 degree thermal switches on the heatsinks, it would turn off under heavy load. Upgraded to 90 degree switches and now gives no trouble at all. I notice one of the resistors on the board has discoloured a bit, but is no real cause for concern. Oneday I'd like to try a modified version with 21193/4 pairs in the output stage, upgraded drivers and front end with about 50v rails. I have enough 21193/4s to replace the 29/3055 devices, so I might do that oneday too.
Quoted from the SC website.. "The process basically involves increasing the main supply rails to ±50V, changing the output transistors to MJ15003/MJ15004 (TO-3 types), Q1-Q3 to BC556, Q4 & Q5 to BF469 and Q6 to BF470 and increasing the power supply capacitor values and voltage ratings to 63V. Naturally a much bigger transformer is also required." I guess if you did use a 30v toroid and you had trouble, upgrading the devices would be the fix? |
| SC480 Troubles.... | Tensop | Solid State | 50 | 9th May 2010 11:34 AM |
| jaycar sc480 t03 ver 2 | johndoe | Solid State | 1 | 17th November 2008 04:58 AM |
| SC480's trouble | rotorhed | Solid State | 0 | 9th September 2007 05:07 PM |
| Modifying the SC480 for 2 ohm load | guitar_joe | Solid State | 6 | 10th August 2007 06:09 PM |
| SC480 Amplifier Kit Problem | Stefan1 | Solid State | 16 | 22nd August 2006 12:11 PM |
| Page generated in 0.07393 seconds (72.39% PHP - 27.61% MySQL) with 11 queries |
