Need help wiring an SAE A501 for 220V
Old 26th February 2006, 05:47 PM   #1
testlab is offline testlab  United States
testlab's Avatar
Default Need help wiring an SAE A501 for 220V
I have an A501 amplifier I need to wire for a 220V primary. Does anyone have hook up info?
It's not whether you win or lose, it's how you lay the blame.
Old 18th November 2006, 12:49 PM   #2
gni is offline gni  United States
gni's Avatar
Default rewire for 220VAC
If inside there are any unused taps on the transformer it
might be possible internally. Remember. . .we are stepping down
the voltage from 120VAC to 40VAC (about 3:1 wind ratio). In a
220VAC situation. . .we will need an almost 6:1 wind ratio to result
the same 40VAC output from the transformer.
Or you could buy a step-down transformer that plugs into the wall
and steps the voltage down before the amp.
Or you could test the voltages and buy a 220VAC version of the
transformer and wire it in. . .internally or externally. . .
Good Luck and let us know how it goes.
Chris Browne
Old 21st November 2006, 01:02 PM   #3
testlab's Avatar
Default Need to say goodbye
To those of you on this site. I regret to inform you that "Testlab" is no longer with us. This is his wife and he passed away August 10, 2006. His real name was Al Sekeet and was a wonderful man.
Please remember him in all of your prayers as his is making the music in heaven sound so much better.
Old 21st November 2006, 08:47 PM   #4
gni's Avatar
Default Regrets
I am so sorry for your loss. Thank-you for letting all of us at
the diyAudio forums know.
Chris Browne
Need help wiring an SAE A501 for 220VHide this!Advertise here!
Wanted: DIY Paradise Charlize, OR Decware Taboo (220V), OR Almarro A205 (220V) Jolojl Swap Meet 0 28th August 2006 11:31 AM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
12V-220V(ac) to 12V-50V(dc) raszvan Car Audio 0 16th June 2005 08:28 AM
How to use SAE A501 Amp, 1980's 321uam Solid State 2 25th September 2004 08:32 AM
60Hz/220V?? chrille Tubes / Valves 6 11th August 2002 11:26 AM
