Old 24th February 2006, 10:14 AM   #1
Onvinyl's Avatar
Default dc-servo and inverted signal
is there a way to use an dc-servo for an audio-opamp if I use the opamp in inverted mode?
If I would use that walt jung servo (Page 26 / 6.24 Fig. 6.17), one would get a low-pass around 40Hz (39.2k/0.1uF) attanuated by 1M for a given signal.
If there are more, or even more serious drawbacks I'd like to know...
The offset I have to deal with is aprox. 20mV, so I guess it will be next to useless to feed the compensation pins (1/5), right?
So, any hints for me?
Rüdiger
Old 24th February 2006, 11:30 AM   #2
40Hz lowpass filter sounds too high for DC servo.
I would expect about 1Hz
Old 24th February 2006, 11:35 AM   #3
Onvinyl's Avatar
Andrew,
I did not mean the servo-F, but if you connect the servos output to the summing point, and feed the signal to that inverted input, the signal in turn sees that low-pass, meaning, only Fs under 40 Hz will pass unattanuated, and that would barley be acceptable.
Rüdiger
Old 24th February 2006, 12:08 PM   #4
Hi On,
the servo will try to remove most of your bass signals with the filter set that high.
It does not matter whether you go inverting or non inverting.
Old 24th February 2006, 12:26 PM   #5
Onvinyl's Avatar
Andrew,
not the filter is set that high, the filter is around 1,5Hz with (1M/0.1uF). But the output of the servo (you've got to look the provided link) serves as an unwanted input when using inverted topo.
Rüdiger
Old 24th February 2006, 12:41 PM   #6
Electrons are yellow and more is better!
peranders's Avatar
Inverting or non-inverting, it doesn't matter.
If you check my gainclone you can see how I have done. The pcb can handle both inverting and non-inverting amps with or without DC-servo.
http://home.swipnet.se/~w-50719/hifi/gainclone
Why don't you test my simulation? I have used the freeware LTSpice from www.linear.com
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 24th February 2006, 04:43 PM   #7
Onvinyl's Avatar
Hi Peranders,
I will check your files before asking more silly questions
What a good practice to post sim-files, thanks!
Rüdiger
Old 28th February 2006, 07:48 AM   #8
Onvinyl's Avatar
Peranders,
all my issues are solved with your files, thanks a lot!
Rüdiger
Old 28th February 2006, 08:17 AM   #9
peranders's Avatar
A DC-servo is just an active feedback element and this is very pedagogical if you simulate it. You'll notice also that care must be taken if the servo has less supply voltage than the main amp.
What happends if you put out 10-20 Hz at full power? You must deside for yourself lower limit in frequency at full output power when the servo is not yet saturated => distortion.
PCB design of parallel of two inverted LM3886 with buffer and dc-servo. Roushon Chip Amps 74 11th April 2012 11:17 AM
Does digital data inverted results in analog signal inveted? Tubeee Digital Source 27 7th June 2005 12:34 PM
noob question: inverted/non-inverted dieselpower Chip Amps 2 20th December 2004 09:19 PM
Circuit questions - Inverted vs non-inverted (again) alvinlim Chip Amps 4 1st July 2003 11:27 AM
Copyright ©1999-2013 diyAudio
