Old 23rd February 2006, 06:51 PM   #1
Default mj11015/16
What is the maximum voltage(+/-) for those darlingtons?(i would use them in power amp
Thanx
Old 23rd February 2006, 07:00 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi smokingmachine,
These are rated for 120 Vc-e, so supply rails of +-60 VDC would be right on the edge. I wouldn't go past 45 or 50 V on your supplies and that leaves very little room.
-Chris
Old 23rd February 2006, 08:13 PM   #3
which one should i use than(i need bipolars for +- 80v----->90v)?
Are there any bipolars that would match mj11015/16 but that they are rated to higher voltage?
Old 23rd February 2006, 08:19 PM   #4
anatech's Avatar
Hi smokingmachine,
Normally, one would use standard audio outputs like the MJ21195 and MJ21196. The collector current rating is lower. You would also use audio driver transistors, like another one of these. Note that you should be using 4 to 6 of these outputs per type for this output power. A large heatsink will be required.
Can you post the schematic you intend to use? There may be other issues at these high supply voltages.
-Chris
Old 23rd February 2006, 09:14 PM   #5
I have schematic on a paper so I can not post it!I will try to do some photos and than posted it!!!
so there arent any bipolars that would be rated for +-85V?
Old 23rd February 2006, 09:33 PM   #6
anatech's Avatar
How many outputs do you think you need per channel?
How much power do you expect to get?
-Chris
Old 24th February 2006, 04:42 AM   #7
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi Smoking,
Here is a small list of outputs from On-Semi typically used for audio applications. It is a .xls file, but must use zip to attach here.
All the trouble I've ever been in started out as fun......
Old 24th February 2006, 11:36 AM   #8
Hi Smoking,
there are hundreds of BJTs suitable for +-90V.
Look for Vce0>180V.
However, if you choose some close to this limit you will often find that the SOAR at 90V is not as good as one rated at 230Vce0.
Download the datasheets for a few and start extracting the permitted current at your chosen rail voltage to make comparisons.
MJE 21193/4 as well as the 21195/6 mentioned earlier are possible candidates.
regards Andrew T.
Old 24th February 2006, 12:14 PM   #9
i would use 6 darlingtons per volatge rail and the power would be around 800w rms!!!!
if the amp could deliver 600w+rms at 2 ohm load at +-56V, then it could deliver around 800wrms at 4 ohm load at +-80V?
Old 24th February 2006, 12:42 PM   #10
Hi Smoking.
NO!
600W2r needs 49Vpk. +-56Vdc after rail droop and then subtract amp losses may just give 600W but expect a little less.
800W4r needs 80Vpk. +-80Vdc at the rails will NEVER give 800Winto 4ohms.
regards Andrew T.
Horsetrade: Want MJ11015/6 swap Hitachi FETs mobyd Swap Meet 6 8th August 2010 10:01 AM
Mj11015/16 Kereng Solid State 1 19th August 2004 08:09 AM
Burning temp. of Mj11015 and MJ11016 darkm4n Solid State 17 14th December 2003 01:08 PM
MJ11015 Question.... Dj BASS AMP Solid State 10 30th March 2003 07:02 PM
Page generated in 0.12134 seconds (70.11% PHP - 29.89% MySQL) with 11 queries
