Old 22nd February 2006, 07:03 PM   #1
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
Send a message via Skype™ to VEC7OR
Default My (semi-)reference preamplifier
Long ago I've been thinking about adding a serious preamp to the system, because I want to have a turntable, casette (for "compartibility") and a tuner.
This project is reference wannabe
Ok, the features:
6 channel relay input selector
6 channel relay tape-return selector (most likely I will have this one separate, to select any source, in case I want to record stuff)
128 step (7bit) logarithmic relay attenuator (0.5dB or 1dB per step)
4 level 2 band(treble/bass) relay switched tone control (most likely -3dB 0 +3dB +6dB settings)
RIAA stage for turntable (I know how the curve looks but dont have any idea how this gonna look like)
Built in 3-way crossover (modules are already built, http://images.bite.lt/banga/files/cl...635138c408.jpg)
Level indicators for all channels ? (maybe?)
It will be controlled by static logic IC's (nothing fancy here, no need for MCU, no noises from MCU clock etc.)
Stainless steel case.
I plan using AD797 for input stages (RIAA corrector maybe) for low noise floor, NE5532 elsewhere (BJT input, low noise, besides I like the sound of it), Wima caps in signal circuits, SMD film resistors (the whole thing will be pretty much SMD), russian RES80 sealed, metal can, small signal, gold contact signal relays.
Pretty much all, details of each block in the following posts.
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Old 22nd February 2006, 07:12 PM   #2
VEC7OR's Avatar
Relays.
Old 22nd February 2006, 07:25 PM   #3
VEC7OR's Avatar
Random brain noise.
Some ideas how relay switched tone stack will work.
Finite state automata for it.
How preamp will pretty much look.
Some ideas how to make good looking buttons for it.
Old 22nd February 2006, 09:33 PM   #4
VEC7OR's Avatar
Basic attenuator block.
Exact resistor values to be found.
I plan using these blocks:
(0.5?) 1 2 4 8 16 32 64dB
Maybe instead of 128dB max I'll use 96dB.
Old 22nd February 2006, 09:37 PM   #5
VEC7OR's Avatar
Logic based volume controller with preset, basically 2 reversive asynchronous counters + some logic to ensure that counters dont roll over 0000000 and 1111111.
4 (or maybe 5) upper bits will be fed to (several) 4-to-16 decoders and will display volume as a lighted tick.
Quadrature decoder to be added.
Old 22nd February 2006, 09:39 PM   #6
VEC7OR's Avatar
Input selector blocks.
Uses some D-latches. Simple.
Old 2nd March 2006, 09:26 PM   #7
VEC7OR's Avatar
Pretty standart PSU.
I still think about using discrete regs for +/- 15V lines.
Old 2nd March 2006, 09:29 PM   #8
VEC7OR's Avatar
Tone stack controller, uses 3 simple logic ICs to allow simple +/- control, can be extended to more levels, but i think 4 is sufficient to slightly adjust tonal balance.
Old 2nd March 2006, 09:33 PM   #9
VEC7OR's Avatar
4 led indicator for each tone stack section. Will use 74LS15X (dont remember exactly which one, but the double 2-to-4 decoder)
Old 2nd March 2006, 09:37 PM   #10
VEC7OR's Avatar
32 led "tick" to indicate current volume level, pretty straightforward using 2 4-to-16 decoders + inverter.
Analog parts coming soon.
Probably I will need help on what to use in the RIAA section, I dont even know what preamp is needed for MM/MC, and what is the difference on amplifying those, how much gain, eq ?
"reference" level preamplifier matsuru Solid State 6 5th March 2007 12:16 PM
what is this semi gmphadte Solid State 9 20th October 2006 08:37 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
New ON-semi BJT. anyone used it? rchua77 Solid State 20 15th January 2004 11:05 AM
Semi-Bi-Amp? chris ma Multi-Way 2 26th September 2002 12:46 PM
Page generated in 0.11187 seconds (81.70% PHP - 18.30% MySQL) with 11 queries
