Old 22nd February 2006, 02:38 PM   #1
e-side is offline e-side  Netherlands
Default Amplifier for bi-wiring?
Hello,
I've got a question about the Lecson Stereo amplifier. At the rear side of it there are 4 speaker outputs (see drawing below - the red and black figures are terminals, the black ellipse at 'MM/MC' is a button), while the amplifier is rated at 2 x 40 Watts rms. The terminals are marked for bi-wiring.
I don't have any experience with bi-wiring, so I don't know what I should do with these 4 outputs. I also don't have any information about this amplifier.
Could I connect two terminals to the woofers and the other terminals to the tweeters? I really don't know how to connect my speakers...
thanks in advance
Erwin
Old 22nd February 2006, 04:30 PM   #2
the terminals are simply repeated to allow easy connection of bi-wiring.
Bi-wiring is not mandatory, IMO a better quality single wire works better.
You cannot bi-wire directly to the drivers.
You need a crossover designed to be bi-wired with 4 terminals per speaker.
Otherwise just use one set of terminals per channel.
/sreten.
Old 22nd February 2006, 07:54 PM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I think that bi-wiring is really not worth the effort, its benefits are more aesthetic than acoustic. So instead, you may consider building or buying an active crossover and another amplifier in order to enjoy the true benefits of an active system. However, be aware that such an active crossover would have to be custom tuned in order to match the acoustic properties of the drivers and enclosures employed.
Old 23rd February 2006, 08:51 AM   #4
I believe there are large benefits to be gained in bi-wiring.
I mean the British version with a passive crossover.
I also believe that simply doubling up the cable but still single wiring to the terminals does not bring this benefit.
I think the benefit of tri-wiring is less than separating the bass voltage drop from the wiring to the mid and treble.
Take your black to black from amp to speaker and red to red.
Your two sets of cables to each speaker should be kept as short as possible. They definately don't look as nice as one set.
regards Andrew T.
Sub Wiring BEAN27 Subwoofers 19 6th May 2006 04:14 AM
Inner wiring master_pogus Parts 4 28th November 2005 01:05 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
bi-wiring Dave Jones Multi-Way 13 27th November 2004 05:41 PM
Page generated in 0.07802 seconds (70.40% PHP - 29.60% MySQL) with 11 queries
