I have tried a few searches on the site but can find no threads on single MOSFet Class A amps with inductive loading. Has anyone successfully done this and can tell me about it and what they did? Any schematics? Should this continue as a new thread?
I have built my own single MOSfet amp with resistive loading but understand inductive in the source leg can be achieved. |
#2 |
Good Idea. Choke load doubles your efficiency.
Some one made one using a modified microwave oven transformer, but I don't know if it was mosfet or bipolar. I think it was circlotron. Search microwave, choke, SE amp. |
#3 |
yes
I have seen schematics of a circuit here at diyaudio.com with use of inductors in outputstage, to increase power I do not remember if it was MOSFET and/or single end, but is probable topic name was 'My Class A' or something like that maybe someone else can search and find it
lineup |
#4 | |
I found it!
Thread: My first ever Class A amp. MOSFET Class A with inductor loaded output stage. Schematic: MOSFET Inductor Output Enjoy! ![]()
lineup |
#5 | |
you should be able to quite easy convert that amplifier, you have there, to use a large inductor for load, instead of power resistor. Gudd Lock!
lineup |
#6 | |
#7 | |
But you can get a hint from Circlotron schematic. He has single supply 28V and 3.5A bias in MOSFET. He uses 85mH in parallell with 8 Ohm speaker. If I were you, I should read all his thread (see my link). Maybe you find out some formula or way how to decide inductor value/size. Circlotron is active, maybe he will join in to assist. Circlotron, Last seen online: 22.02.06 10:41 AM (Today)
lineup |
#8 |
Hugh Dean drew a MOSFet output stage with a choke in the source leg for me. His calcs. produced a 63mh unit at about 2A. I’m just trying to find out who else has been down this path. A Hammond 10mh 5A choke cost me $AU53.
I can get chokes wound but at this size (and I need two) the cost may out-weigh the benefit. I would like to try with no voltage stage before so a single fet (I’m using the 2sk1058) and inductive loaded. I realise the power will be well down but I have not found this a problem in the past. |
#9 | ||
Hammond ... hmm, yeah When looking for good Chokes for SolidState power amplifiers we could turn to Tube Valve stuff. They know these things. But is far from impossible to build your own good COILS for Inductive loaded Class A amp output stages. For example Nelson Pass is good with inductor construction. His ZEN Lite uses a lamp light BULB as load for Class A. Light bulbs are somewhat inductive ... Quote:
Attachment shows a more advanced variant: Balanced Zen Lite with four 300 Watt Light Bulbs
lineup |
#10 | |
Hi Lineup!
There is the ZV7 with choke loading. Tyimo |
| mosfet class a/ab amp | p robertson | Solid State | 30 | 9th February 2010 11:07 AM |
| Inductive Germanium Class A | Duo | Solid State | 13 | 3rd June 2008 05:32 PM |
| help!ab class mosfet amp | mbonus | Solid State | 31 | 19th September 2005 04:14 PM |
| Anode Loading Vs. Cathode Loading ? | valveitude | Tubes / Valves | 19 | 22nd July 2005 10:00 PM |
| Page generated in 0.10741 seconds (84.35% PHP - 15.65% MySQL) with 11 queries |
