The Class-H amp and
The Class-H amp and
Old 21st February 2006, 04:17 AM   #1
rtarbell is offline rtarbell  United States
Default The Class-H amp and
I've been keeping up to date on the recent thread about class-h amplifiers, and I wanted to ask a question that I've had for a long time. I know there exists different terminology, so let me state that by class-h, I mean an amplifier where the power supply rails track the output voltage continuously (NOT a rail switching amplifier).
I understand that the class-h amp is often a class-D amplifier set to high efficiency that surrounds a class-AB conventional amp. How can we be sure that the propagation delay over all audio frequencies of interest will be the same? For instance, let us say that we have a spike on the output of the amp (a sharp increase, followed by a sharp decrease).
==> If the class-D amp does not react in time, then the output transistors of the class AB amp will go into saturation on the positive increase (due to the supply rail not increasing as fast as the base voltage at each NPN output device).
==> If the class-D amp reacts too fast, saturation again as the rail will already be on its way down before the base voltage on the output devices of the class AB amp ever completed their increase.
==> How is this problem addressed in successful class-h amps?
Old 21st February 2006, 05:48 PM   #2
Tim__x is offline Tim__x  Canada
Even the largest music transients don't slew all that quickly. 100w into 8ohms at 20k requires 5v/us, so as long as you keep 5 volts of headroom for the linear stage a uS of mismatch is acceptable.
The Class-H amp andHide this!Advertise here!
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 11:17 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Copyright ©1999-2017 diyAudio
