Yamaha R-3,RX-300 bias adjustment
Old 19th February 2006, 02:24 PM   #1
spongebob-2005 is offline spongebob-2005  Germany
Default Yamaha R-3,RX-300 bias adjustment
I need values for bias adjustment in the amplifier section. I think about 9 mV must be ok. Has anyone an exact value or schematic?
Thank you.
- Boris
Old 18th November 2006, 01:21 PM   #2
gni is offline gni  United States
gni's Avatar
Default Bias Adjustments
Check your resistors. . .let's say 0.22 ohms and you have 9mV DC
across them. . .that would be 41 mA. . . it should keep everything
open and working. Don't go over 150 mA is some thought. . . your
amp will just be producing more idle heat. . . I have a Yamaha M-60
service manual and it specifies 10 mV. A good place to start. . .
too little voltage results in too little current to keep your output
devices open. . .thus distortion. The same manual specifies 110 mV
for CLASS A operation. . . That heats the room. . . .keep it warm, but
not hot at idle. . .
Let me know how this works.
Yamaha R-3,RX-300 bias adjustmentHide this!Advertise here!
Fixed Bias adjustment alexmoose Tubes / Valves 9 12th June 2009 02:32 PM
BOZ bias adjustment help rtate Pass Labs 16 11th July 2008 07:04 PM
Replacing the bias adjustment pot? Burnedfingers Solid State 17 8th November 2007 12:31 AM
Bias Adjustment Question dakotadave Tubes / Valves 0 9th July 2006 11:05 PM
KT88 Bias Adjustment batinal Tubes / Valves 7 20th May 2006 05:16 AM
