Old 16th February 2006, 08:05 PM   #1
bobcat is offline bobcat  United Kingdom
Default Ceramic to line
Ok everyone this is going to sound daft, but i have av high quality audio mixer which has two inputs switchable between mag & ceramic cartridge inputs, what i want to do is retain the mag input but convert the ceramic to a line input ! any ideas or circuits would be greatfully appreciated.
Bobcat
Old 17th February 2006, 12:46 PM   #2
clem_o is offline clem_o  Philippines
High quality and it has ceramic cartridge inputs? Well, if you insist.. :-)
You don't need anything to convert it to a line input. Ceramic input stages were designed 'flat', as that kind of cartridge's frequency response (more or less) complemented the RIAA curve.
As is, it may need a bit of tweaking to get the input sensitivity to match - search for 'resistive divider' on google... or use it 'as is' since it's easy enough to compensate by not bringing the mixer input control to 'full up'.
Cheers!
Old 17th February 2006, 05:43 PM   #3
When i say high quality i mean sound quality and build it has loads of inputs cer/ mag /mm /mc line /aux /tape/ balmic/ un balmic/ echo /repeat/ store/ 10 band eq/selective taoe eq e.t.c but i need more line inputs so i will try feeding aknown signal and attenuate to gain the desired results.
Many thanks B/c
Old 18th February 2006, 12:32 AM   #4
Hi bobcat,
If you keep it switched to 'mag' you can try this:
Inverse RIAA
The link shows you how to make a passive network to allow CD output (i.e. line out) to be plugged into phono inputs...
Cheers!
ps: this is in case your 'ceramic' input setting isn't totally flat - some designs put an extra load capacitance, some leave it out.
How to cut ceramic mobyd Tubes / Valves 4 3rd August 2009 12:38 AM
Little help with ceramic cap ID? peace brainerd Parts 1 4th December 2008 08:36 PM
SMD ceramic cap. Which one? antomas Parts 3 12th September 2006 12:05 PM
Ceramic to line bobcat Everything Else 1 18th February 2006 04:05 PM
ceramic to line bobcat Analogue Source 4 17th February 2006 08:29 AM
Page generated in 0.07211 seconds (71.88% PHP - 28.12% MySQL) with 10 queries
