Old 18th February 2006, 11:06 PM   #31
This amp sounds pretty good. The treble is not to **** hot, a cymbal doesn't sound like a cymbal, but the rest is all good.
You will all laugh your butts off when you read here what I used for parts:
Op-amp: LM741
Transistors: TIP 120
Thats all I could get at work. I think I will look for better parts from Digikey and try building it again. Then I will try to build a voltage stage with transistors and the like.
Old 19th February 2006, 02:37 AM   #32
anatech is offline anatech  Canada
anatech's Avatar
Hi David,
A 741 will take the realism out of a cymbal for sure. Two suggestions for you. An LM318 (old part), watch out. They are fast. An NE5534, nothing wrong with this old guy either. You may already have these lying around. RS might even carry one.
-Chris
Old 19th February 2006, 08:43 AM   #33
clem_o is offline clem_o  Philippines
I'm also sure it will sound a bit better when the FB capacitor is reduced! :-)
Furthering Chris' suggestions, how about an LF356? Tame enough, fast, cheap. Or a TL071...
Cheers!
Clem
ps: one other thing - if you do switch to a faster op-amp (uh, what opamp isn't faster than a 741 these days...), don't forget putting bypass capacitors (0.1uF) from each supply rail to ground - near the op-amp.
Old 19th February 2006, 02:35 PM   #34
I agree, I think it will sound better when the fb cap is reduced. I will have to see if we have any smaller ones at work tomorrow. I think there was a low noise instrument op amp of some sort in stores, so I will have to try that op amp as well.
Old 19th February 2006, 03:38 PM   #35
anatech's Avatar
Hi Clem,
I was thinking of output drive capability too. Your suggestions may do it as well. The NE5534A does have a good sound.
And yeah. Almost anything is faster than a 741 type at 0.6 V/uS. I'm trying to figure out how bad things are to get a 741 to oscillate. The feedback cap should have been much smaller as you have pointed out.
-Chris
Old 20th February 2006, 01:01 AM   #36
Hi Chris,
Good point!
Things would have to be pretty bad for a 741 to complain - something like heavy capacitance at the output, or unstable power supply, or bad grouding... - Eva's suggestion of putting in series resistors would be a good idea to decouple the op-amp a bit?
Cheers!
davidallancole,
Maybe it's time to have a good look at your grounding as well!
807 AB2 oscillation maybe? Craig405 Tubes / Valves 27 25th March 2008 10:01 PM
CDP Oscillation emmasdad Digital Source 0 4th January 2006 03:54 PM
Oscillation raveenvijendren Solid State 15 18th December 2005 11:16 AM
oscillation?? wintermute Solid State 8 13th July 2005 01:45 PM
Oscillation udip Solid State 5 31st January 2005 06:43 PM
Page generated in 0.09043 seconds (74.56% PHP - 25.44% MySQL) with 11 queries
