Old 14th February 2006, 08:07 PM   #1
bob_v5 is offline bob_v5  England
Default how to mix stereo into center channel
How can i mix my left and right channel to get a center channel? On the link ive included it show how to do it with opamps, but i want to do it with as few parts as possible. I want to use M6 mixing as explained below.From what ive read mixing the signals with a pair of 12k resistors would work. Is it really that simple?
"The summing amp has a gain of -12dB for two reasons: both the stereo-to-mono conversion and the unbalanced-to-balanced conversion require a gain loss of 6dB. To explain further, the stereo-to-mono conversion uses a convention where the output is (L+R)-6dB. Thus, a sound in the centre of the stereo image is added together and appears at the same level as each of the original channels. As that sound moves to one speaker only, the output of the converter is 6dB less, representing the reduced output heard from a stereo setup. This convention is widespread in broadcasting and is known as M6 - it produces a good compromise on mono equipment while still maintaining the headroom available in the audio path."
http://www.mhennessy.f9.co.uk/preamp/analogue.htm
T-amp for Center Channel? atleer Class D 3 6th August 2007 04:56 PM
mono center channel out to stereo rjeffersondc Tubes / Valves 5 31st December 2005 09:35 AM
Center channel using TB flaevor Multi-Way 2 3rd May 2005 08:27 PM
center channel sidd_raj2002 Multi-Way 14 4th December 2004 02:41 PM
Center Channel bhg41088 Multi-Way 1 5th September 2004 01:57 AM
Page generated in 0.06585 seconds (67.26% PHP - 32.74% MySQL) with 10 queries
