I have a MF A100X which was purchased in a country with 240V AC.
I now live in Canada with 120V AC and would like to use the amp. Appreciate if anyone can help with schematic to convert the voltage. By the way, the backplane of the amp says 240V/120V and I have tried to run the amp with 120V... it works. Is it possible that the A100X has auto-voltage for 240-120???? thanks P |
#2 |
I don't know the amp but a picture of the backplane and a shot of the transformer area could help.
Look inside for a switch marked 120/240. If it's there, you have the answer. /Hugo |
#3 | |
yup-it works,but how good? anyway it will work with half voltage in PSU agree with Netlist-look for switch,but change probably must be made with some soldering; if you are not skilled in that, find some technician locally
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#4 |
I don't recall any switches the last time I looked inside. Soldering is no problem.
Will take another look inside, pics and post during the weekend. Thanks |
#5 |
Hi PTH,
Look at the primary connections of the power transformer (4 wires or more). For 240 VAC they go in series. For 120 VAC they go in parallel. Phase is extremely important. If you are not 100% sure, have someone help you. The fuse value should be doubled I would think. -Chris |
#6 |
I took a look inside:
1: The toroid transformer has only 2 leads to the primary winding 2: on the transformer, there is a label which says 120- 240 V 3: there are no switches 4: and the secondary winding has only 3 leads Thanks all for helping |
#7 | |
if there are no hidden primary leads you can do just this: measure AC voltage of unloaded secondaries (cut or desolder secondary leads from rectifier) then purchase 120VAC unit of MAXIMUM size which you can squeeze in box;just forget VA ratings and search for size
| Musical Fidelity e300 power amp trannys help :( | raymondo | Solid State | 46 | 15th April 2012 05:34 PM |
| Musical Fidelity P270 - strange power off noise | Nrik | Solid State | 13 | 16th March 2012 11:18 PM |
| Musical Fidelity P170 Power Amp | maf_au | Solid State | 66 | 8th December 2011 08:35 PM |
| Page generated in 0.09468 seconds (76.17% PHP - 23.83% MySQL) with 10 queries |
