hum problem with my Sony STR-DB830
Old 14th February 2006, 02:02 PM   #1
KennyBradley is offline KennyBradley  United Kingdom
Default hum problem with my Sony STR-DB830
I have a "hum" problem with my Sony STR-DB830 AV amp.
I get a very annoying hum from all speakers and it doesn't vary when I adjust the volume. I have tried disconnecting every thing except the main speakers, switching off all electrical appliances in the house (including battery operated ones) and grounding the chassis but it makes no difference. I've even tried it in a different house but it's still the same.
I would take it to my local repair shop but they are not interested and there is nowhere else near enough to help.
I'm very much a novice but would greatly appreciate any advice on where to look (in layman's terms).
Everything else seems to work fine and it's not a loud hum, just enough to be really annoying.
Cheers Kenny
Old 18th November 2006, 02:26 PM   #2
gni is offline gni  United States
gni's Avatar
Default Humm
Things that make you go Humm! Look into those pesky old electrolytic
caps. Letting that nasty AC into the system from the transformer.
Clean the boards with air can real good also. Close circuit paths
can mean a hair will short a path. . .
Let me know how it works.
Chris
hum problem with my Sony STR-DB830Hide this!Advertise here!
Sony DTC-790 dat problem dukasound Digital Source 2 3rd October 2008 06:33 PM
CD changer Sony CDX-601 problem LevyB Car Audio 2 25th September 2005 10:47 AM
Sony V-Fet Amp TA-N7B problem Bernhard Solid State 62 2nd March 2005 01:28 PM
sony amp problem supes Solid State 3 1st February 2003 09:09 PM
Copyright ©1999-2017 diyAudio
