Water cooling, practical matters.
Old 25th February 2006, 01:05 AM   #21
powerbecker is offline powerbecker  Germany
snip Eva
That's lovely, do you have more pictures or the entire article?
Hi Eva,
1980 one of my friends put this 80kg monster for "testing" to the german hifi-magazine HiFi-Exklusiv, they done some measurings, the thd was not so famous : At this time a had no meter
Btw, I think this was the last time for technical tests....other mags started only with hearing-"tests"
The article is german written, it is scanned, but for details the pics are too big to put it here.
Heinz!
Old 19th September 2008, 01:31 AM   #22
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by kiwi_abroad
Has anybody experiemented with water cooling. I'm especially interested in making it as socially accpetable as possible (i.e. as invisible and unnoticed as possible)
Originally posted by powerbecker
Once upon a time......
in 1979 I build a 2channel poweramp with 80 workinghorses in two half-bridges.......
.....further components :
1 EI-transformer 4kVA
2 heat-cooler from Fiat124S
3 7l transformer oil
..the expansion vessel was in the container at the top, together with the 2N3055īs. It was made from a folded Perbunan skin also the the tubes must use this material, because the hot oil solves plastics..
Amazing. 30 years ago.
Heat-cooler from Fiat 124S
One amplifier with the power of cars. Like
lineup
Old 19th September 2008, 05:01 AM   #23
ostripper is offline ostripper  United States
ostripper's Avatar
As I put this on the other watercooled thread ,Ill put it
here:
Totally fanless convection.....
All you do is mate this up with a quality (not a cheap thermaltake)
pump, thermal and electrical failsafes wired to the amps
AC (my class AB trips the soft start for thermal).
It's scalable too, you can buy as many of these passive
extrusions as necessary from..
http://www.pc-water-cooling.com
From ASKA:
In the last ten years a huge variety of quiet fans have become available. These are outstanding, particularly the larger 120 x 120mm DC versions with low speed (typically 1800 rpm). Papst make temperature controlled fans which are around 21dBa, and with careful mounting, and use of a plenum chamber, it's possible to bring fan noise to below room ambient.
I agree ,forced air cooling is very effective for AB. I use a
single 80mm panaflow for 2 150W amps and with just
2 -160 x 60mm heatsinks face to face I can't get 20C
over ambient.
Many commercial offerings use REALLY small
heatsinks and get away with it by stuffing a 60mm in
the chassis.(large STK-XXX chip amps)
Old 19th September 2008, 11:09 AM   #24
AKSA is offline AKSA  Australia
Just to further illustrate the range of fans now available, here's a 120x120 using a Sony bearing developed for low noise and long life.
This fan costs around $15, gives 33.5 cfm at just 800rpm, with 100mA current draw at 12V. It emits just 8.7dbA of noise, which is actually extraordinary..... you would not hear it with your ear more than about a foot from the outlet.
With the appropriate heatsink, forced air circulation at this rate would roughly triple the thermal capacity over simple convection and considerably reduce the size of the heatsink. With two back to back MF18-200 heatsinks from Conrad (which present 120x120 frontal area), this would do 350 watts of heat between them at 27C above ambient. This rating is based on an actual test I did some years ago with these heatsinks and around 35 cfm.
Directron
It would seem that water cooling is not really needed these days for a high dissipation Class A amplifier, providing you have the right heatsink and fan combo.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 19th September 2008, 12:26 PM   #25
lineup's Avatar
Interesting.
Such very silent 120x120 mm fans.
But I am not surprised.
The call for very quiet PC systems have increased, constantly.
For 2 equal PCs, you take the most silent one.
So, for PC makers, it is one competitive factor: sound level.
Why this low sound issue has become important
is that many of us have 24/7 broadband IP-connection.
PC will run all the time in our living rooms.
It wasnt like this when we used (very) Slow Modem via telephone lines.
Cost would be proportional to hours online.
lineup
Old 19th September 2008, 12:33 PM   #26
lineup's Avatar
pump
http://www.pc-water-cooling.com/media/konvpro21_150.jpg
ostripper,
can you tell shortly about such pumps
The only pumps I have used, was that air pump
I used when I had fishes in my aquarium.
To put air, oxygene into the water.
lineup
Old 19th September 2008, 07:31 PM   #27
ostripper's Avatar
In response to both ASKA and Lineup in regards to fan noise,
a Pulse Width Modulation circuit -
is the most elegant solution . A class AB amp will
not create much heat at idle so the fan is off at this point (0 DB)
while amplifier abuse is in progress the fan will
scale all the way to max (2500 + RPM) . The good thing about
using this little circuit is you can use any junkbox fan (60-120mm),
the drawback is a little noise from the PWM oscillator, which
can be solved with a shielded cable run to the fan motor.
If I was to use watercooling ,I'd also use this circuit for
fan cooling a smaller heat exchanger as this would reduce size
and expense.
Here's your pump ,Lineup... Click the image to open in full size.
http://www.pc-water-cooling.com/home.html
Pumps are at left ..OS
Old 19th September 2008, 08:37 PM   #28
lineup's Avatar
good
there we have 2 working systems for cooling amplifiers
lineup
Old 22nd September 2008, 03:14 PM   #29
neil_kaye is offline neil_kaye  United States
neil_kaye's Avatar
Here is a new CPU cooler that uses a refrigerant:
http://gizmodo.com/5053065/thermalta...or-for-cooling
Old 22nd September 2008, 03:20 PM   #30
lineup's Avatar
thanks, neil_kaye
here is how it works
lineup
Water cooling, practical matters.Hide this!Advertise here!
Water Cooling loovet Pass Labs 59 12th October 2005 01:49 AM
Water Cooling BrianDonegan Solid State 72 9th March 2005 02:47 PM
Water cooling project yugaaa Solid State 9 21st August 2004 12:28 AM
