Has anybody used the TIP 142's integrated diode? It has a diode that can be forward biased when a + voltage is applied to the emitter in respect to the collector. Could you not take one of these and place it on the heatsink to to act as a thermal compensator for the bias voltage?
#2 |
TIP142 ha got one backwards connected diode across C-E.
It is for protect for backwards currents. This means you should connect one TIP142 the opposite direction to use this diode, and this TIP142 would not be of any use as a transistor. Much better to use some other smaller transistor (or diode) for temp compensation. Can be in TO-126 ot TO-220 case. I can not see any benefits using diode in TIP142 for this. Eventhough it is not impossible to do this.
lineup |
#3 |
hi,
if you have no other choice, you can do that, but just like lineup says, i say you waste a good transistor.
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#4 |
You guys think that its possible, like the diode in a ThermalTrak transistor? Its just that its a waste of a transistor when you can do it with other ways?
#5 | |
ThermalTrak is not the same as a TIP142, the diode is integral and internally connected to the collector emitter, unlike in the therlmaltrack where it is uniquely separate.
#6 | |
Perhaps, a Vbe multiplier could be applied?
All the trouble I've ever been in started out as fun...... |
#7 |
| Page generated in 0.09348 seconds (74.66% PHP - 25.34% MySQL) with 9 queries |
