Way...dude.
So I built this power supply: http://members.aol.com/ecc81/ps48.html ...and R3 is getting too hot. Finger test: 1 to 2 second ....ouch. I've bumped it up to a 5 watter....still hot. Some possibilities : *I replaced one 220uf with a 330uf because it's all I had. *Transformer is a flatpack 40v 300ma.....but its output tested as 48v unloaded. * Had to reduce that R3 from 2.7k to 820 ohms to get a 48v regulated reading (unloaded). (otherwise I got 60v with the 2.7k)* Am using a 317 regulator, not the TL783. * I added a 0.1u poly in paralel with the 10u electro at the output. Nothing else is warming up, not even the trimmer following R3. ------------ How hot is too hot? Should I remove a 220u (or that 33u) cap? Should I be testing this under load? What could be used as a load? (btw...LESSON from a newb:::heh heh, don't use bipolar caps in there...almost had another meltdown )=RR= |
#2 |
I tried placing a 10w 270 ohm plus a 3w 511 ohm in series (=781 ohms)....and the 10w gets a little warm, but the 511 3w still gets too hot.
=RR= |
#3 |
Even if you applied the full 48V across R3 (2.7k), you would only get 0.85W dissipation. A 1W part here shoud be OK. It'll have a surface tenperature getting on for 100 degress C though.
#4 |
Ah! I've just seen you've reduced the value of R3. No wonder it's getting hot!!
If you're using a 317, then the chip does whatever it can to maintain the voltage between output and sense at 1.25V. Check the spec of the 317 against the part originally specified and see what the equivalent parameter is. You may need to change the value of the resistor between the o/p and the sense. |
#5 |
I've just checked the TL783. That uses a 1.25V reference just like the 317. R3 should be a 2.7k just like the schematic shows. Are you sure that you have really got an 82 Ohm resistor for R1?
#6 |
I'll double check when I get home....thx
=RR= (unrelated edit : my first post said "33u" should say "330u") |
#8 |
Measure the voltage drop across the resistor and then you can calculate its dissipated power.
Maybe the resistor is designed to run hot. |
#9 | |
#10 |
RR,
Is it possible you have D5 in backwards? You can bleed off some excess voltage with a resistor between C1 and C2 anodes. If you choose the value right, the regulator will just drop out at full output current, or just beyond. A short will cause a greater drop and possibly save the 317 regulator. It will also get rid of diode hash some more. -Chris |
| +/-15V from +48V Phantom | Pilbromatic | Parts | 4 | 9th August 2009 05:46 AM |
| whu 6800ohms for mic phantom pwr? | SemperFi | Instruments and Amps | 3 | 19th February 2009 04:20 PM |
| Using the phantom power | Gabevee | Instruments and Amps | 2 | 29th July 2005 05:32 AM |
| Phantom Menace | Pbassred | Everything Else | 3 | 19th March 2004 11:19 AM |
| phantom powering non-phantom mics | karambos | Instruments and Amps | 8 | 3rd January 2004 09:21 AM |
| Page generated in 0.13002 seconds (82.70% PHP - 17.30% MySQL) with 10 queries |
