Leach,Krellclone,GAS,SAE,PL400...??? - Page 2 - diyAudio
Old 13th February 2006, 12:34 AM   #11
acenovelty's Avatar
If you want the power, strong bass and clean highs of the old SAE 2401, the Leach SuperAmp on 85-90 volt rails will deliver. Boost the bias up to 150-200 mA if the bass and mids don't satisfy.
It will be much.... more.... expensive than the Krell clone tho.
Two people can keep a secret if one of them is dead.
Old 13th February 2006, 12:56 AM   #12
bawang is offline bawang  Malaysia
Personally, I will build the Leach TIM (the 120W, 8 ohms version). Personal preferance as the output stays at zero volts if one of the supply fuses blow. Can't say this for other amps. Use a bigger heatsink and ramp up the bias to around 200mA or higher..... Try it, all info is free including PCB layout.
Old 13th February 2006, 03:06 AM   #13
Originally posted by bra
....Need final project. I like much of good deep bass, dynamic, huge soundstage and soft highs....
Simply Leach, Super Leach or Krell clone?
I have built the Leach low tim and JLH 10 watt. I prefer the JLH.
Better bass in my opinion and less fatiguing than the Leach.
Leach has much more power of course.
My Leach is biased at 200ma and the JLH 2amps.
My opinion of course
Old 13th February 2006, 07:42 PM   #14
still4given's Avatar
I have built the Low TIM, ( Jens' boards), Two KSA50's, (one set of Jan' s and one set of Pinkmouse's), Two Symasym's, (one set of 5_2 and one set of 5_3), a P101 and an AlephX.
The description you give comes closest to the KSA50 of those amps. The Leach has strong lows and a good soundstage, but I wouldn't call it's highs soft. The A-X has soft highs but weak bass. The Symasym has the best soundstage I have heard to date but it is only about 150wpc and I would define it's high as very detailed.
So, I guess I would say it is going to depend on how you feel about Class A. The KSA would seem to fit your description the best but it is a hot sucker and you either need huge heatsinks or a tunnel with a fan, which makes noise.
I can't speak for the other amps mentioned, as I haven't heard them.
Blessings, Terry
Old 14th February 2006, 04:10 AM   #15
lgreen is online now lgreen  United States
lgreen's Avatar
Originally posted by myhrrhleine
Looks like you've narrowed it down quite a bit.
I'd personally choose the leach over the krell, but only because I know the leach and not the krell.
I'd chose the Krell over the Leach but only because I made a Krell! But I do have Leach boards and they are 2 projects away (doing an Aleph X now). Plus, Bra, you really have to make a Krell after you got everyone else making them. I will say that it was easier than the Aleph X (so far), and that if you like a strong bass response you will not be dissapointed, you can upscale it a little if you want more power. It does get hot though.
Old 14th February 2006, 09:40 AM   #16
bra is offline bra
Thank to all, no other way - Krell !
Old 14th February 2006, 10:43 AM   #17
pinkmouse's Avatar
I don't think you'll be disappointed!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 14th February 2006, 10:48 AM   #18
SKA is much modern connection....but inertia in thinking is great, how I see....
intermittent DC in PL400 Othello Solid State 10 27th June 2009 01:46 PM
KrellClone KSA100-MKII 1000VA toroidal transformer EUROPE GB Fix Group Buys 77 20th January 2009 08:05 PM
KrellClone KSA100-MKII Heatsink+Fan EUROPE GB Fix Group Buys 65 24th November 2008 06:40 PM
KrellClone KSA100-MKII 1000VA toroidal transformer for dual mono GB stolbovoy Group Buys 33 16th June 2008 04:39 PM
infos on PHASE LINEAR PL400 lenti Solid State 4 14th November 2003 11:57 AM
Copyright 1999-2017 diyAudio
