Old 11th February 2006, 05:14 PM   #1
Default Help with Adcom GFA 565 DC offset?
I know that these amps have a problem with DC offset as they age. I have changed out the opamp which nulls the offset and have gotten down to 500 ma from a high of 900 ma, but that is still too high!
I remember that Muscial Concepts used to extensively modify these amps, including disconnecting the DC servo altogether and substituting a 470uf cap and shunt resistor into the feedback loop so that DC would not be amplified any longer.
Does anyone have a detailed analysis or set of instructions on how to implement this change? At this point, I'd rather just ditch the servo and go with the capacitive coupling in the feedback loop.
Or maybe someone has had direct experience with this issue in the 565 and has other ideas?
I greatly appreciate any and all suggestions, as the frustration at this end is definitely rising!
Craig Goff
Camarillo, CA
Old 11th February 2006, 05:19 PM   #2
Tube_Dude's Avatar
Default Re: Help with Adcom GFA 565 DC offset?
Offset is measured in mV not in mA...have you 500mV offset?
Jorge
Old 11th February 2006, 10:39 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi Craig,
I've repaired these under warranty and out. Just finished one and am in the middle of another.
Fix the problem. Period. Do not remove the DC servo. Do not remove the input coupling capacitor. These amps normally give a half volt DC offset at turn on which will drop below 10 mV unless there is something wrong.
Once your amplifier is repaired properly, you can enjoy it for many more years.
-Chris
Adcom GFP-750 Ossi Pass Labs 13 12th May 2009 03:17 PM
Adcom GFA-565 again, fluctuating DC offset haash Solid State 5 4th May 2009 03:08 PM
Adcom GFA-555II with DC Offset sjdemark Solid State 19 28th February 2009 01:33 PM
Adcom pre-amp pot? rj45 Solid State 11 3rd June 2006 07:19 AM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 08:09 PM
Page generated in 0.07265 seconds (67.38% PHP - 32.62% MySQL) with 10 queries
