Old 11th February 2006, 03:55 PM   #1
Default CCS Biased Class A
I have been playing with this for a while. What do you guys think. I am going to go to work today to build it and see how it sounds.
Old 11th February 2006, 04:05 PM   #2
Tube_Dude's Avatar
Default Re: CCS Biased Class A
The CCS is biased at 6 amps?...
But, some like it hot ...
Jorge
Old 11th February 2006, 04:11 PM   #3
Not quite. In the simulation it draws 1.8 A. It puts 12 volts out nicely into 8 ohms, with a 1 V input.
Old 11th February 2006, 04:12 PM   #4
Tube_Dude's Avatar
0,6 Volts (one diode drop ) across 0,1 Ohms is 6 Amps...me thinks...
Jorge
Old 11th February 2006, 04:19 PM   #5
You must have not noticed the 2.5k resistor after the diodes reducing the current.
Old 11th February 2006, 04:28 PM   #6
Tube_Dude's Avatar
That way your CCS is not thermally stable.
Why not simply , to use a 0,3 Ohms emitter resistor..
Jorge
Old 11th February 2006, 04:34 PM   #7
I built a rough one of these at work two weeks ago. That 2.5k resistor I used was a pot so I could adjust the bias current. The transistors are on some pretty big heatsinks. They barely come above room temperature.
Old 11th February 2006, 04:36 PM   #8
Tube_Dude's Avatar
That's ok! ...
Jorge
Old 11th February 2006, 04:51 PM   #9
I just ran some temperature simulations on PSPICE and it showed as it gets warmer the bias current dropped by a few milliamps.
<WTA>Tube biased by LED arwan_zoel Tubes / Valves 1 24th October 2008 02:33 PM
Symasym biased for class A Dr.EM Solid State 29 28th July 2008 06:19 PM
The Importance of Being Biased Nelson Pass Pass Labs 74 26th July 2007 01:58 PM
ccs biased output device davidallancole Solid State 2 26th November 2005 07:33 PM
#19 biased class A Joel Tubes / Valves 33 20th December 2002 05:38 PM
Page generated in 0.08850 seconds (79.30% PHP - 20.70% MySQL) with 11 queries
