I wonder whether any knowledgeable soul here can help with diagnosing a developing fault with a commercial integrated amp.
The amp belongs to my other half and she has had the unit for the best part of a decade. The amp in question is a Denon pma350II. The audible symptoms evident at the right channel are an intermittent scratching sound similar to a poor connection. The has now beginning to be accompanied by the sound cutting out for very brief periods of time. Connections have been checked and speaker reversed to check them. Opinions? Many thanks Mark |
#2 |
Hi Mark,
Start by removing the top cover. Tap the speaker realy while the set runs at a low volume with a non-conductive object. Not a rubber mallet! If the sound cuts in & out, or just changes for the better or worse, you may simply need a new relay. -Chris |
#3 |
Hi Chris
Thanks for your suggestion. I did as you said, but the relays seemed fine. ![]() Cheers Mark |
#4 |
Hi Mark,
I would be looking for broken solder connections after that. It's difficult to say since the amp isn't in front of me right now. Try operating each switch and control slowly to see if one of those are at fault. -Chris |
#5 |
hi there,
have a look under the board, track side check area around level pots and around any input or output plugs / jacks / sockets, basically anything thats chassis mounted and is soldered to the pcb board/s tap very gently with NON metalic object, small screwdriver handle sounds good, power supply rail fuses sometimes loose connection after years too.... hope this help a little, |
| Diagnosing and fixing amplifier fault (loud crackling and popping) | halfgaar | Solid State | 100 | 29th January 2012 10:01 PM |
| Sony TA-8650 Pre-amplifier fault | zedrider | Solid State | 2 | 17th February 2009 02:19 PM |
| Arcam D290 Right Channel fault? | IansMusical | Solid State | 6 | 30th November 2005 04:22 PM |
| Quad els 63 fault diagnosis | nufunkypeople | Planars & Exotics | 2 | 5th February 2005 03:02 AM |
| PS Diagnosis? | sam9 | Solid State | 3 | 1st November 2004 06:59 AM |
| Page generated in 0.08619 seconds (77.52% PHP - 22.48% MySQL) with 10 queries |
