Hello,
I don't know if it's the best place to ask my question but I try... I would like to make a good audio-measure system, something like audio precision but cheaper. I want to make it with a good soundcard but don't know which software to use. Does it exist a soft that can do almost the same things than audio-precision??? Thanks Hugues |
#2 |
Right Mark Audio Analyzer (rmaa) is a start but nobody is giving away AP level functionality that I've seen
With execellent sound card (lynx, emu 1820m, esi juli@) you can come close in some # to AP, they use similar monolithic DACs/ADCs but AP puts more gain and filter switching around them to extend resolution for various industry standardized measurements Anything you cobble together will be slower to setup and use, verification of your measurements/calculations requires more than usual diy persistance but you can get most of what you would need to take and process the measurements in open source sw scilab gives most of matlab's functionality for very advanced signal processing and display - generate test waveforms and process the the results open source sound capture/editing home studio sw may be the way to get the data into the pc measurements could be partially automated with python/java/visual basic |
#3 |
Hi Hugobors,
There are good things, but nothing like a cheap AP that does all what an AP can do. Look at these two : www.purebits.com : I can't get the demo at work at 24 bits, but this means nothing. The seller is Paolo Bitorzi from Italy and he is friendly. www.hpw-works.com : seller is HpW, Hanspeter from Switzerland is a member here, he is very friendly too. I am stil evaluating his demo of HpW Pro and it looks very good. The sound card should be a top quality one. I am thinking of RME DIGI96/8 PAD or LYNX TWO A or LYNX TWO L22. Maybe some others exist, but I don't know. You should look at this interesting thread : DIY Distortion Analyzer/Analysis? I hope this helped you. Regards rephil |
#4 |
The Purebits shop is closed.
300 Euros is a months salary for some of my staff. |
#5 |
What about this one..anybody tried it??
http://www.audiotester.de/ Software i s only half the package.... it seems like a good soundcard will be around 250-300€ nno matter what we do.... the cheap ones are not good enough I think.... |
#6 |
Hi davidsrsb,
Yes the shop at www.purebits.com is closed, but Paolo Guidorzi (not Bitorzi as I erroneously wrote) that wrote this software is selling it there now. Contact him if you are interested in Sample Champion : he is friendly. Sorry, but 300 euros is cheap related to what others charge their software (e.g. Sound Technology). Sound Technology is out of the possibilities of normal diy. Hi AuroraB, audio Tester crashes on my PC. On yours it may be different. Try it. In my experience, Sample Champion and HPW Works (this one is the best I have found related to my needs) don't crash at all. Regards rephil |
#7 |
I have written it once, there is a program so called SpectraPLUS.It is simple to use , and has a built-in spectrum analyzer with distortion measurements, generator , oscilloscope and more.You can get it through e-mule
#8 |
diyAudio Moderator Emeritus
Hi, Davidsrsb,
Apakah encik seorang direktur? Dalam bidang apakah? Berapakah umur anda? Sorry, saya bertanya begini di forum, karena saya tidak mendapati email langsung pada encik |
| WT3 Test Software | bonz | Multi-Way | 2 | 15th January 2008 04:10 AM |
| Active filter test software | 4real | Multi-Way | 4 | 5th October 2004 07:43 PM |
| Test & demo CDs & DVDs / Frequency resp software | mark.carline | Multi-Way | 2 | 25th May 2004 10:57 AM |
| Page generated in 0.09833 seconds (76.72% PHP - 23.28% MySQL) with 10 queries |
