Old 10th February 2006, 12:27 AM   #1
Default need help repairing onix A-120
Hi... I have an onix A-120 which suffered the loss of its right channel. I can't find the schematic online and it certainly didn't come with one. I attempted to fix it but am stuck.
Each channel had a SK C3519/A1386 pair. There was visible damage in the output section on the right side.
1 completely exploded 10uf 50v electrolytic capacitor.
2 burnt-to-crisp 100ohm resistors
1 melted C3519
I took a stab at replacing the broken parts with a MJL3281A/1302A pair from digikey, a 10uf 250v electrolytic, and 2 100ohm resistors that can probobly take a little more voltage than the originals, just judging by the size. I picked the transistor pair because it seemed to have a low probability of being counterfeit. I have more of these parts for the left side so they will match, if I can get the right side working.
When I plugged in the amp, the protect light came on for the right side like it has since it broke, and smoke came off of one of the 100ohm resistors.
I checked and the resistance is still 100ohms so I think it's ok. All the other resistors checked out too. If you can't tell, I don't really know what I'm doing, but I did find that the resistance between the 1st and 2nd pins on the 1302 is 0, but I can't see a short anywhere. I'm not sure how to diagnose individual parts with them all in a circuit.
Can I have some advice? Should I give up and take it to someone who knows how to fix it?
Old 10th February 2006, 06:38 AM   #2
could i have damaged the transistor while soldering it in?
Old 10th February 2006, 06:38 AM   #3
I took the transistor out, and it tests out fine, but there is still a short between those pins. I think I may have found a bad transistor elsewhere in the circuit.
Onix & soap needs a re-cap fatmarley Parts 27 11th February 2011 01:36 PM
Fs: Onix A60 jimmyd53 Swap Meet 1 19th March 2008 08:01 PM
Onix OA 601 Humming ? Rob louth Solid State 0 9th January 2008 09:22 PM
still trying to fix my onix a-120... miekedmr Solid State 33 8th March 2006 12:50 AM
Onix oa 24 Rob louth Solid State 1 16th November 2004 04:04 PM
Page generated in 0.07515 seconds (71.81% PHP - 28.19% MySQL) with 10 queries
