#31 | |
Michael Chua |
#32 |
Banned
The advantage is how it sounds...
Now how do you SIM that???
#33 |
The cross quad is related to the name of Caprio.
It was one of the very linear differential circuits studied by Hephaistos-Gérard Perrot in the magazine L'Audiophile, back in 1988. The conclusions were that : - the linearity is dependant on the good matching of the devices - it is not a very stable circuit with a possible negative input impedance - it does not behave well at start-up or when overloaded. In the same magazine, Hephaistos had a look on the Van De Plaasche's circuit, some of the schematics shown in this thread should be apparented to it. ~~~~~~ Forr §§§ |
#34 |
image insert test
#35 |
I'll try a bigger image this time
#36 |
Hi Guys,
Hopefully I have got this right ![]() I have analysed the xcoupled quad as a simple open loop dif pair with degeneration (Rdeg). Each IP has a 0.1V step. So the total voltage step between + and - IP's = 0.2V. Before we get too far remember that the XCQ inverts polarity so as Q1 goes + its current decreases and as Q2 goes - it's current increases. You have to visualise this clearly or everything after gets confusing. I have added an arbitrary delta BE for each transistor which basically represents the inherent non linearity of a BJT's B-E voltage versus current. So as Q1 goes 0.1V + its delta VBE is 30mV, due to decreasing current, which is comparatively larger than Q2's delta VBE of 10mV. As we all know this is due to Q1's emmitter resistance increasing and Q2's emmitter resistance decreasing. What the XCQ does is transfer the delta VBE from Q1 to Q4 and from Q2 to Q3. This has the resultant effect of linearising the resultant current flow through the dif pair. As can be seen the resultant total emmitter swing of Q3 and Q4 is exactly the same as the IP swing. IP swing = 0.1 + 0.1 = 0.2V Q3/Q4 emmitter swing = 0.12 + 0.08 = 0.2V So the current through the dif pair is completely linearised. As an additional note, since the XCQ reverses phase, as Q1 swings + and its current is reducing, its miller c is now acting as a small + feedback mechanism as opposed to the normal - feedback. This is probably one of the reasons for increased susceptibility to oscillation. As another additional note, it can be seen that since the emmitter swing of Q3 and Q4 are now the same total resultant swing of Q1 and Q2 bases, ie; the inputs, these emmitters constitute a zero impedance. This is probably what is throwing the sims out ans also a reason that this arrangement MUST be degenerated and probably with quite a significant R. Note I have re attached image as original has a few mistakes. I hope I have not been too confusing. Cheers Terry PS, please be constructive with your replies, this took a bit of time to nut out and draw. |
#37 |
revised image please disregard previus 2 images
#38 |
Adding a cascode section makes the original circuit much more stable. Not really suprising that having a large in phase signal on the collector of the input transistor can cause stability problems.
#39 | |
What are the response differences? |
#40 |
The input resistors have an effect
Green trace is 0R1, Red is 100R |
| Diff drive | bigwill | Tubes / Valves | 38 | 6th February 2009 06:33 PM |
| cross-quad and cascomp circuits | rtarbell | Solid State | 15 | 1st September 2007 03:09 PM |
| diff or parallel dac | TJ | Digital Source | 6 | 10th November 2003 01:14 PM |
| Page generated in 0.11059 seconds (79.56% PHP - 20.44% MySQL) with 11 queries |
