Old 8th February 2006, 02:07 PM   #1
aparatusonitus's Avatar
Default Qs. about LTSwitcher CAD
Hi guys,
I have a few qustions about LTSwitcher CAD:
1) How to performe a squarewave/sawwave response from amp circuit, I mean how to define input pulse voltage source (Vinitial, Von, Tdeley, Trise, Tfall, Ton, Tperiod, Ncycles) for 100Hz, 1Khz, 10Khz... and 10mV, 100mV, 1V... input amplitude
2) Is it possible to wieu distortion vs frequency, distortion vs output power, and if it is, how?
3) How to get "accurate" reading for output impedance from transfer analysis, is it OK if I place spice directive .tf V(Out) V1?
Thanks, a
Non é mai abbastanza...
Old 8th February 2006, 03:04 PM   #2
teemuk is offline teemuk  Finland
Default Re: Qs. about LTSwitcher CAD
1) I don´t have the LTSpice right at hand now but i remember that the pulse function of the voltage source had some problems with accepting zero values and gave unpredictable results with them. You can use 0.000... ...00001 for example, just do not use zero.
Then, if i remember right, again, Tperiod should be = (Trise + Tfall + Ton) * 2, which is quite logical. No zero values! Set Vinitial and Von respectivily and Ncycles high enough to give useful readings when voltages have adjusted. (I use at least 0.5 delay before viewing simulation results - note that i do not mean the delay in pulse function now.)
2) Take a look at .step command, it should get you started.
I hope i was able to help you at least a bit,
Teemu K
Old 8th February 2006, 03:16 PM   #3
Hi Teemu K,
Thank you for valuable informations regarding LTSpice, I'll try yours tips & tricks tonight and see
Best, a
Old 9th February 2006, 04:59 AM   #4
jcx is offline jcx  United States
LtSpice is really great but it doesn't do harmonic distortion sweeps, you can collect the points for drawing such a graph from the .four output in the log file by finely stepping the frequency or input amplitude, I have written a VBA macro in Word to extract a matrix from the .four log file text results and passed the data to mathcad for plotting (for a completely different use, I wanted a "describing funcition" plot of the fundamental of a clipped ampifier output as a freq, amplitude surface)
THD really throws away too much valuable information for me to worry about LtSpice lacking a THD sweep
Output Z is easily tested via a active current source load - .tran analysis are more realistic so fine stepping of your current source frequency or ampitude is the best spice "measurement" technique, I avoid nearly all .ac or other linearization based analysis (like tf)
I have posted a number of example sims here, most with LtSpice source files, try searching
by user name: jcx
and optionally containing these words: ltspice swcad sim asc
Old 9th February 2006, 06:43 AM   #5
Originally posted by jcx
LtSpice is really great but it doesn't do harmonic distortion sweeps...
A stupid question: What is a harmonic distortion sweep? Are you perhaps meaning a stepped fourier analysis, because if you are the LTspice can indeed make one although the option is sort of "hidden"...
Teemu K
Old 9th February 2006, 01:53 PM   #6
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
One more question : Can LTSpice simulate a spectrum analyzer , but with only 1 tone passed to input ?
It would be possible to calculate THD then.
Old 9th February 2006, 04:56 PM   #7
Performing an FFT analysis with LTspice goes like this: First make a transient analysis, it should popup a window with a waveform in U, I or P/ t graph. Right click the graph and select FFT from the menu. Select which node you want to plot, (note that in the opening menu you can also overwrite the node with your own plot function). After this another window will open to show the spectrum in a dB / f graph. The bigger the time for transient analysis is (more samples) the more accurate the FFT analysis will be.
I still haven't found an option that would calculate the average THD ratio manually though.
Teemu K
Old 9th February 2006, 06:13 PM   #8
Press Wieu -> Spice Error Log after FFT analysis
Old 9th February 2006, 06:25 PM   #9
Here i found DB to THD conversion :
http://www.sengpielaudio.com/calculator-thd.htm
Old 11th February 2006, 03:27 PM   #10
One Q about FFT analysis : if i take a voltage source , set it at 1K @ 1V.
"-" of the source is grounded , and i perform a FFT analysis of "+" of it.
I get very strange spectrum analysis with badly distorted signal.Why ?
Page generated in 0.10659 seconds (82.81% PHP - 17.19% MySQL) with 10 queries
