I hv bought cd changer from USA. It works on 120V AC. We hv 230~240V electricity. There r two transformers in the circuit connected in parallel to input 120V) primary) . I want to use them for 240V input by connecting in series as shown in the attached picture. The size of two transformers is 25% diiferent. I want ur views about my idea of using them in series for 240V input.
#2 | |
U can use them in series, but do not forget the rule, slowest ship determines the speed of entire fleet. Likewise the transformer of the least current rating will determine the maximum current flow at primary side. This combination I think U can try only if the current consumption is lower. If power amp is in built then I advise, do noy try proposed series combination ! Jai Hind, |
#3 |
I wouldn't advise it. Due to the different power draws by each of the transformers, the 240v primary will not be split into even 120-120. One transformer will get more than 120v while the other one less.
#4 |
They can't be safely connected in series, at least without some mechanism to ensure that the voltage is evenly split (that may be as simple as a tiny autotransformer or conventional transformer having a 0-115-230V tapped primary ).
#5 |
Don't
regards Andrew T. |
#6 |
You should use an autotransformer to lower mains from 240 to 120 and do not mod your CD unit.
#7 |
This will work with some tiny 3VA transformer, you may even fit it into the case.
| Hammond 270 series power transformer? | Norris Wilson | Tubes / Valves | 13 | 22nd February 2007 02:54 PM |
| dual secondary transformer connected in series | Leolabs | Solid State | 2 | 7th October 2006 12:38 AM |
| Crest SK series Amp Transformer for sale on ebay... | imix500 | Swap Meet | 3 | 15th January 2006 01:05 AM |
| Transformer series wiring questions | chipco3434 | Power Supplies | 6 | 9th January 2005 01:48 AM |
| transformer in series | bigpanda | Solid State | 5 | 10th July 2004 06:58 PM |
| Page generated in 0.08079 seconds (75.63% PHP - 24.37% MySQL) with 11 queries |
