Just wondering, what kind of an amp is this? Output power?Pbassred said:My power amp's spec tells me that it uses 8.4A with 120V. Using I=VA , power consumption is 1008watts. Now; if the voltage supply changes to 230V, am I right in saying that:
A=I/V = 1008/230 = 4.3A ?
Is it that simple?.
Hi Pbassred,
is your wall socket outlet fed from a ring or a spur from the distribution board?
I'll explain your loading options once I know.
If you're not sure and you are competent (safe) with mains electric then you can check this yourself.
See if there are two cables feeding the back of your wall socket outlet or only one set of cables?
If you have two sets, then power off at the distribution board, disconnect (very carefully) the red supply from the screw connector. Insulate both ends by placing each bare end into a terminal strip connector. Test the voltage on both bare ends. If only one is live you are on a spur (or your ring is faulty). If both are live then you are on a ring.
TAKE CARE with mains voltage.
An easy way to check if you have switched the correct MCB:- insert a noisy drill or similar into the wall socket outlet and lock the off/on switch to on. Go to the fuse board and turn off/ withdraw the fuse. If the drill keeps running you have pulled the wrong fuse. Keep trying.
Andrew,
Unlikely that I would ever run 1800 Watts at home! This is Sound reinforcement gear. In that case the answer is likely to be;...
A cracked single 13A socket, below a radiator, above a beer soaked carpet, shared with the fruit machine. At least, it was last time I played!
- embarrassed to ask but
