Old 6th February 2006, 02:39 PM   #1
beppe61 is offline beppe61  Italy
Default From a schematic to a PCB.
Dear Friends,
first of all I have to state that I am very bad at English and electronics.
Then a kind question.
Many time I have been amazed by the beauty of PCBs designed by DIYAUDIO friends starting from schematics.
Is there any software that from a schematic can output a PCB design ?
Some of these PCBs seem to me even much better built that commercial ones !
Real pieces of art.
In particular my dream would be to design a PCB for a re-edition of the HK Citation 12 with a single pair of Sanken as outputs.
A very powerful and nice sounding 60 watter/channel.
I saw a wonderful PCB for the Mosfet 12 version, but I am afraid it would not work for the original Citation 12 schematic.
What I like of the Citation 12 is that it should have the minimum number of active components needed.
Very minimalist design. I like it greatly.
Any suggestion would be very appreciated.
Thank you very much indeed.
Kind regards,
beppe
Old 6th February 2006, 03:10 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
If you want to fool around you could test Eagle for free, small pcb is the limitation.
www.cadsoft.de
It's not that hard to make a nice looking pcb (but make a good pcb may be a bit harder...).
/Per-Anders (my first name) or P-A as my friends call me
Old 6th February 2006, 03:42 PM   #3
You should take a look at ExpressPCB
They supply free schematic entry and PCB layout software with no significant limitations to the home builder. The catch is that it's their own proprietary format so you have to have them build the boards. I recently had some amplifier drive boards made and was pleased with the quality.
Old 7th February 2006, 01:43 PM   #4
www.cadsoft.de
Dear Mr. Peranders,
what a wonderful result ! My sincere congratulations !
I would start with something very basic first.
I will try the software.
Thank you very much.
beppe
Old 7th February 2006, 01:45 PM   #5
Dear Mr. Bettinger,
thank you so much for your very valuable advice.
Kind regards,
beppe
Old 7th February 2006, 05:42 PM   #6
Like Mike said, you have to have someone work out your pcb if you are using PCBxpress. You could not print the traces out and do your own etching, drilling... etc. It's always difficult to find the right tools to do your work.
Old 7th February 2006, 06:14 PM   #7
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
ExpressPCB allows you to print PCBs.
I am wondering if there is a good layout router program ?
Thanks,
Lukas.
Old 7th February 2006, 06:29 PM   #8
pinkmouse's Avatar
Not for audio. It's manual routing all the way!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 8th February 2006, 12:59 AM   #9
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Yes,manual routing is good for audio design
Old 8th February 2006, 06:41 AM   #10
peranders's Avatar
I'll recommend that you try some software with both schematic _and_ pcb layout. It's easier to have a correct schematic to start with. Eagle may be a good alternative.
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 01:49 PM
DBX 500 schematic d3imlay Solid State 0 2nd August 2008 05:12 PM
F3 schematic kenev Pass Labs 2 24th January 2008 03:24 PM
Need Six-pac amp schematic Sarge Tubes / Valves 1 31st July 2004 08:30 PM
Page generated in 0.12282 seconds (71.18% PHP - 28.82% MySQL) with 10 queries
