Old 6th February 2006, 02:14 AM   #11
Steve Eddy's Avatar
Originally posted by davidsrsb
If germanium devices got more than a little warm they died.
Yeah, they were hardly the most robust solid state devices.
se
Old 6th February 2006, 02:15 AM   #12
Tube_Dude's Avatar
Originally posted by Mark A. Gulbrandsen
I just love that T.I. ad from the 50's...
November 1953...two month after I was born ...in september 1953...
Jorge
Old 6th February 2006, 02:19 AM   #13
Steve Eddy's Avatar
I just love that T.I. ad from the 50's... "20 Times Tested" Today you're lucky if they test every 20,000th device!
Yeah. But materials processing and manufacturing have come a long way since then too.
se
Old 6th February 2006, 02:30 AM   #14
clem_o is offline clem_o  Philippines
My brother has a Sony radio from 1972 - if I recall its supposed to have been a 'first IC radio'. About as big as a match-box. I remember seeing it when I was a lot younger, not sure if its still around!
Cheers!
Old 6th February 2006, 12:01 PM   #15
jackinnj's Avatar
i didn't get my first transistor radio until 1961 -- my dad gave me his when he purchased a new one -- it was a 7-transistor GE model and it is somewhere in my mother's house! Up until I received this radio I used a crystal set from a Remco kit to listen to the late-night talkers and baseball.
http://people.msoe.edu/~reyer/regency/QST_3-53-p97.jpg
Old 6th February 2006, 12:17 PM   #16
SY's Avatar
Jack, you're probably old enough to remember the transistor wars? This is a 10 transistor radio, for another $5 you can get a 15 transistor radio. Top of the line is a 20 transistor radio; that one must REALLY be good!
One of the electronics mags at the time (Electronics Illustrated, I think) ran an expose, where they bought a bunch of the high transistor count radios, examined the guts, and found about 5 transistors actually working, the rest either diode connected or not connected at all.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 6th February 2006, 12:37 PM   #17
dnsey is offline dnsey  United Kingdom
Rather like the 'stereo' ones, which had one speaker mounted in the centre of a cardboard tube, with grilles at each end!
Who mentioned BO**
Old 7th February 2006, 10:50 AM   #18
What I remember the most was how long the battery lasted in one of the old transistor radios. The more transistors the less life on the old 9 volt. I had one that would spend a battery in about an hour.
Old 7th February 2006, 12:29 PM   #19
Default Re: Re: Re: Re: The first pocket transistor radio
Originally posted by Tube_Dude
Triodes only for the 3 terminals , because the impedance "looking" in the collector of the transistor is very high ( hundreds of KOhms ) it look more , like a pentode .
Germaniums had much lower output resistance than silicon transistors, far more like a triode.
I remember a physics practical around 1971 measuring transistor curves. The task was written with an AC128 germanium in mind and I was very confused by the silicon device that I was given.
Old 7th February 2006, 02:56 PM   #20
Tube_Dude's Avatar
Default Re: Re: Re: Re: Re: The first pocket transistor radio
Look at the specifications in the data sheet.
http://people.msoe.edu/~reyer/regency/ti_ad_11-53.jpg
Collector resistance (minimum ) ... 0,2 MOhms - 0,4 MOhms..
The proverbial imperfect constant current source , hardly a triode at all , I'm afraid...
Cheers
Jorge
Radio output before transistor amp Calamaro Analogue Source 0 10th October 2008 01:00 PM
Need Help With Early 60's Transistor Radio 65blkbkgt Car Audio 44 7th January 2008 10:18 AM
crystal radio transistor amplifier Sparky OR Solid State 2 6th April 2006 01:20 AM
transistor radio?????? jamerick Everything Else 6 18th November 2002 11:50 AM
Page generated in 0.10852 seconds (74.01% PHP - 25.99% MySQL) with 10 queries
