I recently acquired an old (15 years) rotel amp. When i plugged it in there was no output in one channel. I eventually traced this to blown fuse. Swapping over the good fuse confirms that both channels are working, and i plan to get a replacement (6.3A 250v slow blow i believe).
Am i right in thinking that a blown fuse could be symptomatic of something more seriously wrong? (i know nothing about amps) A further look around the insides reveals a slightly blackened look on a small part of the pre-amp/input pcb. Yet everything still seems to works OK (well replacement fuse not withstanding). Should i soak test the amp after replacing the fuse? I wondered if whatever burnt out is likely to give me more problems or if it might be a part of the preamp section i dont use (phono cartridge input) Any help/advice would be great |
#2 |
It could be an indication of bad solderings, especially in the brown areas. I have no idea about your soldering skills so take care if this would be your first attempt.
Could you post some high res. pictures of the brown coloured areas? Solderside? /Hugo |
#3 |
Hi, thanks for your reply, I havent touched the amp other than to change the fuse. My soldering is OK (ive changed op-amps, capacitors etc in cd players but not amps). The discolouring appears to be component side not solder side. I cant post pics until tomorrow. Soldering all looks pretty good as its a commercial component (although admittedly thats not always much of a guarantee!)
#4 |
There is a minor amount of soot on the inside of case above where the problem area is. Perhaps one or more of the electrolytic caps failed? (il post a pic tomorrow).
#5 |
Fuses 'can' jump by accident but they do rarely.
If all seems ok now, I'd let the amp play at moderate volume and keep it in observation for a while. Is the fuse located in the power supply or the output? /Hugo |
#6 |
I'll check soak test it when ive got another fuse. Fuse that had blown was in the output.
#7 | |
/Hugo |
#8 | |
Thats what i thought! But not mine! |
#9 |
#10 |
Hi Rotellian
> a blown fuse could be symptomatic of something more seriously wrong? Most often, yes, but not necessarily. A fuse can be blown because it becomes old : every time there is a switch on/off, some particles of metal leave the fusible wire, which blows when too thin. ~~~~~ Forr §§§ |
| Rotel RCD 971 Carriage Problem | trombone | Digital Source | 13 | 31st August 2008 05:54 PM |
| Rotel RCC-955 Problem | sorenj07 | Digital Source | 0 | 27th February 2007 01:51 AM |
| Rotel RA-931 problem | njholland | Solid State | 3 | 16th July 2006 04:01 PM |
| Rotel 855 problem | Mikelo | Digital Source | 3 | 11th January 2005 03:47 PM |
| Rotel RCD965BX LE Problem | johnmarkp | Digital Source | 6 | 9th May 2004 08:29 PM |
| Page generated in 0.10070 seconds (77.14% PHP - 22.86% MySQL) with 10 queries |
