Rotel amp problem
Rotel amp problem
Old 6th February 2006, 12:24 PM   #11
Thijs666 is offline Thijs666  Netherlands
That dark stuff could be some kind of glue they used to fasten the elco's to the print. Do the other elco's also have this black stuff at their base?
I would be more concerned about that transistor-thingy next to the elco. It seems like this one is getting pretty hot. It also seems like the package is split in 2
Old 6th February 2006, 12:33 PM   #12
Rotellian is offline Rotellian  United Kingdom
The only glue in evidence is clear stuff on the main PS caps elsewhere in the amp. This stuff seems to have oozed down due to gravity (its mounted vertically). Ive been worried about the what i assume is a regulator as it seems to have slightly browned the casing of the cap next to it. However i think its meant to look like that with regards to splitting in 2 as it seems to uniform.
Old 6th February 2006, 05:49 PM   #13
Fuse replaced and amp working i both channels now for 30 mins with no problems. However there seems to be a small amount of heat coming from what i believe to be the regulator mentioned above (although i guess it could be soemthing else).
Not sure if this is normal or not? (its not in the power amp section so my guess is not)
Old 6th February 2006, 06:20 PM   #14
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
That glue is not the nicest stuff they could come up with to stick the elco's but I wouldn't be too concerned about it.
Furthermore, some parts get warm, regulators usually do and that's normal. If the amp plays fine, just enjoy it.
/Hugo
Old 6th February 2006, 06:32 PM   #15
Thanks for all the help guys. Im really not sure that stuff is glue, it just doesnt look like glue (or enough to hold anything) and is not on other caps. Ill soak test it some more, but i think the possibly faulty parts might actually be for the phono section and not something i need so i might remove the pcb and trace the layout more accurately.
Rotel amp problemHide this!Advertise here!
Rotel RCD965BX LE Problem johnmarkp Digital Source 10 2nd February 2014 06:12 PM
Rotel RCD 971 Carriage Problem trombone Digital Source 13 31st August 2008 06:54 PM
Rotel RCC-955 Problem sorenj07 Digital Source 0 27th February 2007 02:51 AM
Rotel RA-931 problem njholland Solid State 3 16th July 2006 05:01 PM
Rotel 855 problem Mikelo Digital Source 3 11th January 2005 04:47 PM
Copyright ©1999-2017 diyAudio
