Old 12th February 2006, 02:44 PM   #11
bob123 is offline bob123  United Kingdom
your input is directly connected to the ouput - thats a no no and this cicuit would not work and probaly distroy what ever is attached to it!
Old 12th February 2006, 08:27 PM   #12
Dimitar Kyuchuk's Avatar
This circuit differs from the first one ... R10 and R11 are missed, Q9 is connected differently and this input is surely not there ... the input and output are shorted ...
Old 12th February 2006, 08:48 PM   #13
ilimzn is offline ilimzn  Croatia
...Not to mention that there is no bias current to be seen for the bias network or driver BJTs Q3 and Q5 therefore no bias current at all, and this is probably a very good thing because if there was some, Q9, the bias servo, has it's BE junction shorted, so the bias voltage between bases of Q3 and Q5 would be very high and result in at least 6 transistors out of the 7 active ones dying shortly after power-up. D7 and D8 would not do a thing considering there is no bias current and Q9 BE is shorted - also they appear shorted in the schematic, you might want to check that. One of R15/R16 or R19/R20 is extra, why not just use a single resistor instead of two in series, at least on paper, as it will make the schematic easyer to read. I am only guessing here as to where the bias current is to come for the driver stage, either way,D3-Q7, D4-Q4 will keep the output stage from doing anything very useful as most current would be diverted through them, instead of going into the driver bases.
I suspect this is supposed to be a power follower, except this might be the wrong universe for it
Old 12th February 2006, 09:43 PM   #14
rodolfo is offline rodolfo  Mexico
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Copyright ©1999-2013 diyAudio
