My Paciific Stereo Concept 6.5's right channel is out. When I tap a thermal fuse (white radial box w/ paste) attachted to the power amp heatsinks, it sometimes comes back to a brief, quiet, crackly life. My question is, does this seems characteristic of a blown fuse? To have one channel work and the other not seems like something else... wouldn't it just not work at all if the fuse was blown? Also, it seems that the preamp section is the culprit - when i touch an input to the power amp, there is a strong hum on both channels. Any ideas? Thanks!
#2 |
Did it Himself
A white radial box could also be an 'emitter' resistor which is part of the output stage.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
This particular box was pasted onto both heatsinks and has the markings: "U12 125V 6A 83 95C UCHIYA"
#4 | |
Regards.
Jorge |
#5 |
Well... the fuse isn't blown, any suggestions on how to proceed?
#6 |
Look on the underside of the board and start resoldering. You can try tapping components / board gently with a pencil, and try to find the spot most sensitive to the mechanical vibrations.
| Creating 5.1 Multi Channel sound from 2 channel | jenkrich | Everything Else | 5 | 1st September 2009 07:29 AM |
| 4 channel conversion to mono 1 channel | iUSERTLO72p | Car Audio | 24 | 25th October 2007 05:07 PM |
| HELP!: Channel volume very very low, other channel fine. | harrisni | Solid State | 2 | 20th September 2006 11:10 AM |
| My 4 channel car Amp distorting on 1 channel (large pics) | MikeHunt79 | Car Audio | 9 | 3rd September 2003 06:41 AM |
| Help quick! 4 Channel > 2 Channel? | zmoz | Car Audio | 3 | 5th July 2003 08:48 PM |
| Page generated in 0.08744 seconds (73.53% PHP - 26.47% MySQL) with 10 queries |
