Need Help Fixing Denon AVR-1602
Old 3rd February 2006, 09:13 PM   #1
bludytiger is offline bludytiger  Canada
Default Need Help Fixing Denon AVR-1602
I got this Denon amp from a friend that needs some work. Aparintly something happend to it when someone was running a kareoke machine through it.
When pluged in the On/Standby LED will light. When pressing power the On/Standby LED with flash then go solid but nothing apears on the display. I can select what speakrs to use (A or B). All the LED's seem to work but nothing ever comes on the display. I don't get any sound or video from the unit, I don't know if anything is damaged with that because for all I know the unit might be starting up in the setup mode but I can't see it on display.
I downloaded the manual and did the Initialization of the Microprocessor wich is sepose to set everything to Factory Defualts. During the reset, everything on the display is sepose to flash in intervals of 1 second, but only the LEDs flash.
I also accidently downloaded the scematics for the system.
If anyone could point me in the right direction of where I sould start, it would be appreciated.
Old 4th February 2006, 12:51 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
First you need to check all the supply voltage.
Old 4th February 2006, 01:38 AM   #3
Alrighty, how would I go about that?
Old 4th February 2006, 04:41 PM   #4
I was working on the unit lastnight with someone and we seem to think that one of the voltage regulators is blown, most likely the 7805. My vom meter was acting funny lastnight and didn't want to read voltage :s so today I'll go borrow another to test it and I'll keep you posted of the results.
Need Help Fixing Denon AVR-1602Hide this!Advertise here!
tad 1602 hornloading kartsmart Multi-Way 10 10th October 2012 06:55 PM
Help on QSC PLX 1602 minniew Solid State 2 7th December 2007 12:54 PM
Denon AVR-1602 bludytiger Solid State 0 2nd February 2006 07:23 AM
Repairing Denon AVR-1602 Brannigan Solid State 26 1st November 2005 01:41 AM
ok one more time tad 1602 kartsmart Multi-Way 17 18th June 2005 04:12 PM
Copyright ©1999-2017 diyAudio
