Dried out electrolytics in an amp. - Page 3 - diyAudio
Old 3rd February 2006, 02:26 PM   #21
Electrons are yellow and more is better!
peranders's Avatar
Beppe it's a good idea to have your email button enabled. Your email address won't get revealed unless you answer.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 3rd February 2006, 02:42 PM   #22
beppe61 is offline beppe61  Italy
Dear Mr. Peranders,
" Beppe it's a good idea to have your email button enabled.
Your email address won't get revealed unless you answer."
How can I do that ?
Thank you very much again.
Kind regards,
beppe
Old 3rd February 2006, 05:57 PM   #23
peranders's Avatar
Push "USER CP" at the top
then EDIT OPTIONS choose "Hide Email Address?" check NO
Your has a flat response down to 3.39 Hz.
The feedback consists of (47 uF+ 1k) + 22 k => gain is 23 times
The smoothing is 2 x 10000 uF per channel but.... the transformer has no centertap still it has ground somewhere??? An error in the schematic?
Otherwise the design is pretty basic. No rocket science
Old 3rd February 2006, 10:21 PM   #24
peranders's Avatar
Beppe, could you do some reverse engineering.
1 Does the transformer only have two wires from the secondary winding?
2 Is it true that the center of the big 10000 uF pair of caps are connected with only one wire between the channels?
3 Where does the speaker ground go to?
Old 4th February 2006, 08:21 AM   #25
[QUOTE]Originally posted by peranders
[B]Push "USER CP" at the top
- Thank you Mr. Peranders. Done !
- So the weak bass response is not depending on the design.
- I confirm this. Some not well identified "custom made" caps.
I do not know anything on their quality.
- Dear Mr. Peranders, I checked and actually the transfo has two windings that go to two diodes bridges and centertap.
So there is an error in the schematic.
- I am all but an expert but it seemed the same to me.
But this is a mine field.
I remember a test of a british solid state amp where the reviewer said that the design was "obsolete".
It became his reference amp for the quality of sound.
But in this case I ma not talking about shadings.
I miss the low bass! the sound is very thin indeed.
I am afraid that the quality of the transformer is not that great.
My opinion is that of a basic but linear design undermined by bad components, firstly the transformer.
But I am gambling here.
What is your opinion?
Thank you so much.
Kind regards,
beppe
Old 4th February 2006, 08:43 AM   #26
[B]Beppe, could you do some reverse engineering.
- There are 2 wires for each secondary (i.e. 4 wires) that come out from the transfo and go to two separated diodes bridges (one for each channel).
- The grounds of the two pairs of filter caps are connected together and go to a single screw where is connected the speakers ground as well.
I do not hear any particular noise or hum etc.
I am more and more convinced that this lack of energy in the bass could be related with a bad execution of the transfo (i.e. low regulation factor or high impedance secondaries).
As I said a nice simple even basic design let down by a cheap transformer.
In my experience all great power amps begin with a huge and high performance transformer.
I am even thinking to buy two separate 500 VA toroids, just to try a rescue.
I saw some nice ones from Talema (7% of regulation factor).
Thank you sincerely.
Have a nice weekend.
beppe
Old 4th February 2006, 09:02 AM   #27
peranders's Avatar
If you say the transformer has 4 wires, then the schematic has some errors, don't agree? So if you have two secondary windings you have proabaly a DC connected speaker output and this means flat response down to 3 Hz but not at full power of course.
If those 47 uF is a bit dry then you will have a reduced bass. If you want to test, just solder in a 47 or 100 uF in parallel. It can't harm to test.
Have you located the caps? Near the input, I think it says C609, in series with 1 k.
Old 4th February 2006, 09:55 AM   #28
[B]If you say the transformer has 4 wires, then the schematic has some errors, don't agree?
- Definitely Mr. Peranders.
- Yes this is the case
- that is the reason of my original question: if a dried out cap in the feedback loop can give reduced bass response.
Thank you so much for this very interesting advice.
- I will do it in the next days.
I swear Mr. Peranders, just a one last question.
I see 4A fuses (marked F601 and F603 on both channel) in series with the voltage rails after the filter caps.
Could they be some sort of bottle-neck for the supply?
May I bypass them with a piece of wire ?
I really do not like to see fuses between the power supply and the amplification circuit.
It seems quite strange to me.
Thank you sincerely again.
Kind regards,
beppe
Old 4th February 2006, 01:10 PM   #29
peranders's Avatar
Don't do anything with the fuses. Just check that the conact pressure is enough and the metallic surface of the fuses seems OK, meaning good contact. Sometimes it's enough only to roll them or take out and put themn back again.
Old 4th February 2006, 01:24 PM   #30
[B] Don't do anything with the fuses.
Just check that the conact ...
I asked you because I found a thread about fuse impact on sound (i.e. someone state the ceramic ones are better than glass ones) so I wondered ...
Anyway thank you very much again.
Kind regards,
beppe
Old electrolytics never die, they only.... Pbassred Solid State 13 9th October 2010 01:55 PM
is there anything to help dried/old paper surrounds? freddi Full Range 18 8th February 2009 09:38 PM
ARC D90 needs new electrolytics Pete22 Tubes / Valves 9 4th August 2006 12:31 AM
Dried Capacitors OMNIFEX Solid State 7 15th February 2005 03:55 PM
Electrolytics 101 Frazzled Parts 3 21st May 2004 02:49 AM
Copyright ©1999-2017 diyAudio
