Dried out electrolytics in an amp. - Page 2 - diyAudio
Old 2nd February 2006, 07:46 PM   #11
Electrons are yellow and more is better!
peranders's Avatar
A 15 years old amp used once in a while in home environment is not an age really. Caps will last longer but if they are warm or even hot they can last about a year in harsh applications. My guess is that after 10 years you can suspect something and after 15 most caps are rather functional but 20 years or more may be a lottery. Notice I'm not talking about hot tube amps.
If the smoothing is gone you will get a huge hum if the amp will work at all.
The "thin-ness" may also be a design feature. The amp has maybe never been able to reproduce low frequence's.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 3rd February 2006, 12:04 PM   #12
beppe61 is offline beppe61  Italy
[QUOTE]Originally posted by peranders
[B] ...
Dear Mr . Peranders,
thank you so much for your always kind and precious replies.
> If the smoothing is gone you will get a huge hum if the amp will work at all....
- Luckily is not my case. No hum at all. so the filter caps should work.
- And this sounds really unbelievable to me.
So unbelievable that I take the liberty to send you a copy of the service manual of the amp to very kindly ask you to see if there is anything limiting the bass response.
Thank you so much.
Kind regards,
beppe
Old 3rd February 2006, 12:11 PM   #13
Dear Mr. Peranders,
unfortunately I cannot attach any file to a private e-mail.
I would just like to ask you this anyway.
There is no coupling cap at the input of the amp.
In the feedback loop there is a 47uF/100V electrolytic cap to ground.
It would be better to change it to a 220uF or even 330uF?
Could the bass response improve ?
Thank you so much indeed.
Kind regards,
beppe
Old 3rd February 2006, 12:19 PM   #14
What amp type is it ?
Charles
Old 3rd February 2006, 12:27 PM   #15
[QUOTE]Originally posted by phase_accurate
[B]What amp type is it ?
Charles
Dear Mr. Charles,
if you provide me with a your e-mail address where I can attach a file I will send you the Service Manual of the amp, that is a 100W/8ohm stereo power amp.
As you can understand I would prefer not to upload it here without the permission of the manufacturer.
Please let me know if you are interested to give a look.
Kind regards,
beppe
Old 3rd February 2006, 01:01 PM   #16
peranders's Avatar
I can have a look, check my homepage for the email address.
Old 3rd February 2006, 01:05 PM   #17
[B]I can have a look, check my homepage for the email address.
Thank you so much dear Mr. Peranders.
I knew that Swedish people are great !
Thank you sincerely.
Kind regards,
beppe
Old 3rd February 2006, 01:12 PM   #18
peranders's Avatar
[QUOTE]Originally posted by beppe61
[B]
Old 3rd February 2006, 01:13 PM   #19
Just click the e-mail field down here !
Charles
Old 3rd February 2006, 01:23 PM   #20
Charles
Ok Mr. Charles,
nevertheless I cannot attach the above mentioned file.
I do not have the permission to do it publicly.
If you could give me an other address then I will send you the file.
Kind regards,
bg
Old electrolytics never die, they only.... Pbassred Solid State 13 9th October 2010 12:55 PM
is there anything to help dried/old paper surrounds? freddi Full Range 18 8th February 2009 08:38 PM
ARC D90 needs new electrolytics Pete22 Tubes / Valves 9 3rd August 2006 11:31 PM
Dried Capacitors OMNIFEX Solid State 7 15th February 2005 02:55 PM
Electrolytics 101 Frazzled Parts 3 21st May 2004 01:49 AM
Copyright ©1999-2017 diyAudio
