Old 1st February 2006, 02:40 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Cool Lizi final
This is the near final version of her,but still got a few question:
-What's the usable bias current of the JFETs???
-What's the usable value of the drain resistors(Which related the bias current.)???
The JFETs maybe the 2SK246/J103 pair or the 2N545x/6x pair.
Old 1st February 2006, 03:39 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
How much current, depends totally on which JFET you use.
There is a value in datasheet MAX Current.
I usually set the current to be less than 50% of this MAX Current.
What value of R13/R14 also depends on which JFET transistor you use.
Voltage Gate-Source to set a specific current will be different
for different JFETs.
Also will be different for each individual JFET.
This is why JFETs often are 'matched'. This means you select two JFETs with similiar VoltGS value.
After you have chosen JFETs ( finding P-JFET is the tricky bit )
and set current with R13, R14 ( N-JFET and P-JFET have different qualities !)
you select R4/R7 to set a suitable current in Q1/Q2 stage.
lineup
latest version of Lizi Leolabs Solid State 95 29th June 2008 04:01 AM
Workable Lizi final Leolabs Solid State 19 15th May 2006 03:44 AM
Another look of Lizi Leolabs Solid State 4 7th December 2005 03:49 PM
Page generated in 0.11899 seconds (47.46% PHP - 52.54% MySQL) with 11 queries
