Old 24th February 2010, 08:34 AM   #171
nsaidor is offline nsaidor  Sri Lanka
That's sounds great!
could someone please help me getting SST404 dual JFETs or any other suggestion as an alternative one?
Cheers
-Navin.
Old 24th February 2010, 01:06 PM   #172
Cheers
-Navin.
VISHAY SILICONIX|SST404-E3.|JFET | Farnell España
Old 7th March 2010, 07:22 AM   #173
Yeah, they do not have stocks!
Old 20th May 2010, 09:27 PM   #174
satoru is offline satoru  United States
Cheers
-Navin.
Hi Navin,
Have you been successful on locating dual JFETs? SST404 is a low gm device and 2N3954~8, LS843~5 and 2SK30 (single) fall into the same group (2~3 mS @ 1 mA, something like that). Gluing together two 2SK30 whould be the cheapest solution but the DC drift can be a nuisance.
Good luck!
Satoru
Old 9th September 2010, 01:30 PM   #175
Default eti 5000 rebuild with exicon`s
i have the amps running with exicon fets ..only the 125 watt ones yet to try the 250 watt ones yet if you want the detailed mods i did to the amp to rebuild it please email me and i would be glad to help you with everthing {i was the manager of the kit dept from 1983-1987...sparkey@hotkey.net.au
Old 9th September 2010, 01:34 PM   #176
i have everthing u need to know...sparkey@hotkey.net.au
Old 17th April 2011, 01:16 PM   #177
from sparkeey ,,i have looked at your amp pic`s very nice i must say ..on the otherhand i have been building the eti 477 amps mow for 27 years ..i can do it blindfolded... although i have made quite a few with exicons now and was wondering if the 470 pf by pas caps on the drain sorce need to be alterd in capacitance i also changed the gate resistors to 680 ohm and have made a few other mods with the help of ian ...regards brian ..sparkey@hotkey.net.au
Old 3rd June 2011, 01:36 PM   #178
if any one interested, the SST404 is found at Future Electronics (is a Calogic distributor)
Search result for : sst404 - Future Electronics
Old 17th August 2011, 11:13 PM   #179
Liliya is offline Liliya  Norway
I have vistit this adress:A HiFi Power Amp
I find this amplifier very interesting.
In her schema I do wonder what are connected to T7, 8,9,10 and 11??
I wrote Suzie a mail, but have not got any answer.
Any one who knows??
Eivind Stillingen
Old 18th August 2011, 06:06 AM   #180
suzyj is offline suzyj  Australia-Aboriginal
suzyj's Avatar
I thought it was obvious, so didn't explain in the text.
They allow you to run the input stages off a different power supply to the output stages. The latfets have ~10-12V Vgs, which means that in order for the output to pull hard to the rail, the gates have to be pulled beyond the rail.
The idea was that you could run the output stage off +/- 56V @ 200+ W, and the input stages off +/- 65V @ 5 odd W. That way you'd get a little more than the usual 140W into an 8 Ohm load.
In practice I just bridge T7-T8, and T9-T10, and leave T11 unconnected.
Power problem: Denon AVP-5000 preamp... Heard of one of these? the#1 Solid State 0 27th April 2007 03:48 AM
Power MOSFET chlim74 Car Audio 15 25th December 2006 05:36 PM
Hi-power mosfet Stefano Pass Labs 1 20th October 2003 10:03 PM
Page generated in 0.09172 seconds (85.78% PHP - 14.22% MySQL) with 11 queries
