#61 |
Stuart,
Thanks for your reply ... Thats was I thought ... I've built tube stuff in the past, but rarely touch SS stuff. I've heard that lateral mos-fet does not have to be that well matched in a set ? I have 8 Hitachi K176 and 8 J56 - I believed that are graded and matched by the seller. I'm going to put them in a Counterpoint SA20 Chassis using Denis Output stage and I have an Aikido board octal board stuffed for 12SL7 and 12SN7. |
#62 |
I was wondering if the Mosscode front end would be able to drive 10 each npn and pnp transistors? I have an Adcom 565 with a bad input board. I would very much like to tube it.
The DC rails are 83+-vdc. I have also thought about tubing my Adcom 545 with the mosfit outputs rated a 100wpc. Thanks Ben |
#63 |
THE MOSCODE FRONT END WILL DRIVE YOUR ADCOM 545. THERE ARE TWO DESIGNS ON THE WEB THAT COULD HELP YOU.
GIVE ME A COUPLE OF DAYS AND I WILL LOOK FOR THEM AND POST THEM IF I CAN TAKE CARE IVEY
"Have you seen my electrons? Their are about, . that big. Very little fellows.., kinda small". |
#64 |
I like the digilander circuit...taking the capcitors out of the circuit....can be modified with the mosfets diving a class AB BJT outputstage....
#65 | |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Fabrizio72 |
| MOSKIDO - Hybrid Tube/MOSFET Amplifier | Kashmire | Pass Labs | 7 | 22nd September 2011 08:30 PM |
| 24V Tube IRF610 MOSFET Hybrid HPA | lineup | Solid State | 10 | 23rd October 2008 02:36 AM |
| Hybrid Tube / Mosfet Amplifier | poynton | Tubes / Valves | 8 | 10th August 2007 05:32 PM |
| bass guitar amp hybrid Tube/mosfet ?? | partyjups | Instruments and Amps | 1 | 19th April 2004 01:08 PM |
| Page generated in 0.08254 seconds (71.30% PHP - 28.70% MySQL) with 11 queries |
