Old 30th January 2006, 03:03 PM   #1
Send a message via AIM to clovi_kate Send a message via MSN to clovi_kate Send a message via Yahoo to clovi_kate
Default check this out..higher the voltage of this amp
i have this design and my power supply is higher than the supply of this design..so i will be going to change output transistors into 2SC5200 and 2SA1943, and add more to make 4pnp and 4npn..
i need your comment guyss
thanks a lot..
Ryan Jan
Old 30th January 2006, 03:24 PM   #2
MOER is offline MOER  United States
Default amplifier design
Not a very good design.
The differential pairs are simply driven by resistors from the rails. Poor CMRR and if you change the power supply voltage then the currents up the differential pairs will change which will then change the current up the VAS which will then change your idling current which if it is too high will blow up your amplifier.
The trimmer in the bias circuit is dangerous. If the trimmer wiper lifts, you output stage will blow instantly since all bias control will be lost.
There are many good designs on the web. This circuit which you have posted is a classic full complementary design which has been done for over thirty years now.
Old 30th January 2006, 03:27 PM   #3
Default Amplifier design
Dending on your rails, the VAS transistors will not be Ok as far as dissipation is concerned. The pre-drivers (TIP41C/42C) are a very poor choice and are only rated at 100v Vceo so be careull
There are many TO220 driver pairs which are vastly superior to the antiqauted TIP series.
based on your post that you intend to replace the outputs with Tosh 5200/1943, I presume your rail voltages will be in the order of +/- 60 to +/-80v, am I correct?
Old 30th January 2006, 03:27 PM   #4
Default thank you
do u have any good design with exactly or higher than 200rms at 8ohms?..but not Fet trnasistors..thanl you
Ryan Jan..
Old 30th January 2006, 03:30 PM   #5
edl is offline edl  Hungary
edl's Avatar
Default Re: thank you
Ryan Jan..
What kind of psu have you got?
For 200W/8ohm-RMS you'll need about +/-75V...
Best regards,
Old 30th January 2006, 04:26 PM   #6
MikeB is offline MikeB  Germany
MikeB's Avatar
Default Re: Re: thank you
Best regards,
Hmm, i calculate 62v, including 5v rail losses ?
Mike
Old 30th January 2006, 04:58 PM   #7
edl's Avatar
Sorry, I mistyped, it's +/-70V.
For true RMS 200W on 8ohm at such low as 20Hz and in every condition, using 2*10.000uF per channel I need: sqrt(200*16)+[(200/8)*sqrt2]+6 idle voltage. That means about 70V. My other formula gives the same 70V. So you need a 2*50V trafo.
Let's refer to Phase Linear 400, that produces 2*200W RMS on 8ohm, with +/-75V, with 5600uF caps in the psu.
edl
Old 30th January 2006, 05:04 PM   #8
MikeB's Avatar
I obviously forgot the voltagedrop in the caps...
Mike
Old 30th January 2006, 05:21 PM   #9
Ryan Jan..
try this one:
http://users.otenet.gr/~athsam/power_amp_300w.htm
Old 31st January 2006, 01:04 AM   #10
clem_o is offline clem_o  Philippines
Originally posted by BlackMTX
try this one:
Hmm, that doesn't look like a very stable design - there are improvements over the 1st schematic, in terms of power-supply decoupling of the input stages and constant-current source for their emitters; output SOA limiting - yet the input pair isn't balanced, the VAS is running wide open (save for an RC to one supply rail), rather lowish FB corner (330pF || 10K).
Cheers!
Cap voltage can I go higher captaink Digital Source 3 3rd November 2007 08:56 PM
higher voltage than BC550/560? kubeek Parts 10 12th September 2006 04:52 PM
Running BLS on higher voltage Illusus Pass Labs 3 12th March 2005 05:21 AM
higher voltage PS Steven Koay Chip Amps 5 10th September 2003 11:29 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
Page generated in 0.11989 seconds (76.07% PHP - 23.93% MySQL) with 11 queries
