protection mode won't go off
Old 30th January 2006, 03:43 PM   #1
Darkcrusher is offline Darkcrusher  Belgium
Default protection mode won't go off
I think the speaker terminals got short cutted cause when I noticed there wasn't any sound , they were lose and protection led switched on, I disconnected speakers and checked fuses, and when i turn my amp on, it goes again in protection. I fear that I blowed it up. What can I check for to fix it ? Could it be a power transistor I need to replace ? Any help is welcome......
Old 31st January 2006, 02:10 AM   #2
clem_o is offline clem_o  Philippines
Open up the amplifier and look for additional fuses, on the amplifier board. If one of these opened, it would cause a huge DC offset on the amplifier output and force the protection circuit on all the time.
If there aren't any other fuses inside, then yes, suspect shorted output (and driver?!) transistors...
Cheers!
Old 1st February 2006, 01:22 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi Darkcrusher,
What is the make and model?
-Chris
Old 2nd February 2006, 11:11 AM   #4
Default model and status
Well, its a TOXIX amp model TX-1600N . its a 4 x 400W amp and sin bridges are possible to have 2x400W @ 1x 800W . I demounted it and desolderd 2 power mosfets, all 4 driving trans, 2 of the 8 power trans (1 looked suspecious) and compared with my ohm meter, but they have same resistance in all maners of measerement. I solderd everything back in place now, and will test if the protection might go off if i shortcut and open wires of the temperature sensor, since that one could cause the prob too. If thats not the prob then I think its for trashcan , unless you or someone else comes up with something....
Old 2nd February 2006, 12:54 PM   #5
Stocker is offline Stocker  United States
There is usually some help to be had for fixing amplifiers here. If you want to do some hard work on your own, that is.
Jesus loves you.
Old 2nd February 2006, 03:10 PM   #6
anatech's Avatar
Hi Darkcrusher,
Ahhhh, we are talking about a car power amplifier!
Check your connections to B+ and Ground. They have to be excellent, so don't just look at them, reconnect them and use star washers to ground to ensure a good connection.
Also check the small wire from the battery negative to the car body. I've seen people smoke those off.
-Chris
protection mode won't go offHide this!Advertise here!
yamaha m-50 repair (amp goes into protection mode) Zorac Solid State 13 7th April 2015 05:58 PM
Nad 304 Protection Mode sirhenry Solid State 2 14th May 2009 10:46 AM
amp protection mode ? chrissy14xsi Car Audio 40 14th March 2009 03:00 AM
Amp Protection Mode sseabrook07 Car Audio 3 29th October 2006 03:26 PM
denon receiver going to protection mode Anfield Solid State 12 7th September 2006 05:21 PM
Copyright ©1999-2017 diyAudio
