Con someone look at this buffer/mixer for me? Con someone look at this buffer/mixer for me? - diyAudio
Old 30th January 2006, 04:02 AM   #1
aletheian is offline aletheian  United States
aletheian's Avatar
Default Con someone look at this buffer/mixer for me?
I am making a little 4 channel PA out of an few LM3886 chips, and I need to rig up a simple buffer, so I threw this idea down. I only included the buffers... they will be fed from 4 discrete preamps with gain controlls, and then sent out to an "insert" for processing... then into these buffers.
Is there a better way to do this? Do I even need the buffers? I figured they would keep from loss from input impedance and maybe kill any ground loops a bit.
Heghlu'meH QaQ jajvam!
Old 30th January 2006, 05:57 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
In same way as when paralleling OP-amps or LM3886,
you need to use a series resistor from output of each of 4 transistors.
They are all connected to the output capacitor.
This way each input can be different and voltage difference will be across these resistors.
lineup
Old 30th January 2006, 07:03 PM   #3
aletheian's Avatar
Crap... I forgot those... thanx. Is it OK other than that? Pretty simple.. I just wanted to bounce it off someone else.
Old 31st January 2006, 12:13 AM   #4
clem_o is offline clem_o  Philippines
It would seem simpler to use one op-amp configured as a summing amplifier to do the job. If you use high values for the input resistors to the summing amp, the source impedance(s) of the previous stages should become pretty much negligible. A FET-input opamp should be able to work with those impedances properly...
Cheers!
Old 31st January 2006, 12:16 AM   #5
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Yup. Google "virtual earth mixer" for the schematic.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 31st January 2006, 02:28 AM   #6
aletheian's Avatar
Cheers!
That's "plan B" in case the fets did not work out. I really wanted to use discreets, and I thought that I might avoid ground lops that way, which might be a problem for a virtual earth setup... meybe not in this context though.. I dunno...
Old 31st January 2006, 04:05 AM   #7
Howdy - don't see how using discrete FETs can avoid ground loops. Each FET still has a ground, which will get common'd through the power supply...
Cheers!
Con someone look at this buffer/mixer for me?Hide this!Advertise here!
DIY DJ mixer Bricolo Analog Line Level 34 7th January 2011 12:00 PM
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
mixer or pre-amp adan888 Solid State 1 18th January 2005 07:00 PM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
DJ Mixer Samuel Jayaraj Solid State 4 2nd February 2002 09:07 PM
Copyright 1999-2017 diyAudio
