cheap but convincing amp
Old 29th January 2006, 09:04 PM   #1
beamnet is offline beamnet  Netherlands
beamnet's Avatar
Send a message via MSN to beamnet
Default cheap but convincing amp
My brother has very cool vinyl decks, very neat dali speakers and a good dvd player.
Now what bothers me that he has a very big sony amp. The kind that lets yous digitally adjust bass, select presets and stuff. That gives me a cold chill. I think it sounds cheap and harsh.
Now i am looking to make an amp that convinces him that a good discrete amp is better.
I am looking for a schematic that's cheap and uses readily availeable components. i have some xformers and caps.
Nothing fancy, but over 50 watt.
any suggestions?
Bas
Old 29th January 2006, 09:11 PM   #2
MikeB is offline MikeB  Germany
MikeB's Avatar
Hmm, maybe a symasym ? 60watts into 8ohm, 100watts into 4ohm. (see my WWW)
Mike
Old 30th January 2006, 02:46 AM   #3
jaycee is offline jaycee  United Kingdom
P3A. Only "fancy" parts are the outputs, and at a pinch you can use MJ15003/4 or similar.
Old 30th January 2006, 03:46 AM   #4
clem_o is offline clem_o  Philippines
Check if there is a direct patch to the amplifier stage, skipping the digital stage(s). On my Sony amp there is a "direct 5.1" input, that seems to jump everything else except the volume control. Works wonders when its straight-patched, and may help convince him that a good power amp is worth the investment.
Cheers!
Old 30th January 2006, 12:50 PM   #5
beamnet's Avatar
What do you mean?
Ik have been looking at that project!
Bas
Old 30th January 2006, 01:04 PM   #6
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by beamnet
... and at a pinch you can use MJ15003/4 or similar ...
What do you mean?
I have been looking at that project!
Bas
'at a pinch'
means:
- if you get into a situation where you have not many other options
- like an emergency situation
in this case:
if you cant find original output power transistors, you can use MJ15003/MJ15004 or MJ15024/MJ15025
lineup
cheap but convincing ampHide this!Advertise here!
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
I used a cheap cheap clock Sunsun22 Digital Source 33 7th April 2006 02:44 PM
Cheap finish for my cheap subwoofer? mazeroth Subwoofers 19 26th July 2004 01:47 PM
