I have just tried a fully tested 12V unit to power a dac with a current requirement of 670mA but the unit just shuts down. I can find nonreference in the literature on current limit.
Am I overdrawing current? |
#2 |
Andrew told me a few weeks ago that the current is limited by the preregulator.
#3 |
Between 200 and 500mA
To see : Alwsr rev2.9rev0051.pdf just above figure 2 ( page10 ) Darry |
#4 |
#5 | |
Electrons are yellow and more is better!
Do you have cooling, not Max current can be calculated backwards. Hfe 25 min, typ 100 of the D44H11 Current through driver 1V/R1 => 10 mA That gives max current somewhere between 250-1000 mA but more like the higher value. The very current limit is set by the LM317, check datasheet for this (1-1.5 A)
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
What is your input voltage?
------------------------------------------------------------------------------------15-17V ------------------------------------------------------------------------------------ Do you have cooling, not ------------------------------------------------------------------------------------ Max current can be calculated backwards. Hfe 25 min, typ 100 of the D44H11 Current through driver 1V/R1 => 10 mA That gives max current somewhere between 250-1000 mA but more like the higher value. ------------------------------------------------------------------------------------ These values are about right; so why does my regulator shut down at 600mA? |
#7 |
Notice at least 250 mA but how much load can it take then?
What does "shut down" mean? A bit voltage drop or what? Your input voltage with ripple taken into account, min voltage? It must be 15-16 V at least plus ripple.
#8 | |
My apology; I treated a 15V regulator as though it was 12V; the thing never started even though the LED was on. Happilly now getting 650 mA on 12 V with 18V input. Now testing geat sink temperature. My rme dac sounds much better on ALW than LT1085 variable or manufacturer's 'good' switching supply. No hf fixx and more open!. |
| A superior VAS clamp and VAS current limit for the Blameless. | GK | Solid State | 128 | 19th October 2011 03:03 PM |
| How to make current limit for PC supply? | luka | Power Supplies | 10 | 27th February 2007 03:31 PM |
| Which NTC to limit inrush current | Mlaen | Solid State | 24 | 10th February 2005 12:52 AM |
| LED current limit resistor value calculator | tomchaoda | Parts | 0 | 21st September 2004 04:24 PM |
| Current limit of EL84 grid? | G | Tubes / Valves | 10 | 22nd February 2003 07:08 PM |
| Page generated in 0.09736 seconds (76.86% PHP - 23.14% MySQL) with 10 queries |
