Hi! So, I bought a pair of MOSFET monoblocks and said myself to share it here
This is symetrical amp. with 120W/4Ohm output power. The amp, itself, has a differential amp. on input made of T1 to T4 with a current power sources T5 and T6 and LED diodes D1 and D2. Transistors T1, T2, T3 and T4 are coupled to system to make an output drift as small as it can. Using T7 and T8 is this system joined as driver for power transistors. Differential phase is powered by U lower approx. 13V (D3 and D4) for better behaviour during limitation (is in differential, not in end phase). Transistor T8 is screwed to heatsink with power mosfets to monitor its tempetature, which is transformed to idle current control. Resistors R37 and R38 sets power factor to 3. Null output U is set by R5, idle current by R25. Constructing: Make sure NOT to remove or change + and - on LEDs (they are not for light!!!) (as I did... ). This burn-out the outupt mosfets. (tested...). Avoid short circuit at output, not connected power source ground or only one pole. Amp dont has to have output load (but dont test it for a long time if U dont need it). Power resistors put approx. 5mm above PCB for output heat. I didnt find any problems - except LEDs - because of I am an idiot... (why the hell they put LEDs on it - I dont need them, I have a LED on the box.... |
#2 |
Schematics...
#3 |
Part list...
#4 |
The LED's are part of the current sources for the diff. input pair. They are an important part of the circuit, they just happen to emit light as well.
#5 |
what voltage is the voltage amp running on? I am confused by the D3/4, R31/32 and R29/30 combination. Is there voltage amplification in the final driver and common source stage? The gate resistors seem very low at 15R. 100R upwards is more common. Finally the red LEDs probably have about 1v8 across them. This gives about 1v2 across R18/19 generating about 2.5mA as an LTP tail current. This equates to about 1.2mA LTP currents and can be checked for balance by measuring the voltage drop across the emitter resistors R11 thro' R14. All should be about 27mV. I would disconnect your speakers before doing this and maybe substitute a dummy load of 8r to 22r.
regards Andrew T. |
#6 | |
150 Ohm/ 68 Ohm Gain in output stage should be something like 3. Looks like an elektor amplifier using IRF540 IRF9540.
lineup |
#7 | |
#8 |
A better mosfet based amp was published in elektor years back using BUZ series of mosfets..i had substituted with 2X irf540's..per arm..gave 240 watts..pls refer "Elektor back issues..or later when i myself find the issue...
SivanandBalan |
#9 |
Hi Lamicz,
with the 13V zeners in the supply rails you cannot have the same voltage on the output stage and the voltage stage.
regards Andrew T. |
| DYNACO 120W AMP for DYNA A-451 | edrel sison | Tubes / Valves | 32 | 26th January 2011 02:24 AM |
| interesting class A amp, 120w into 8ohms | space2000 | Solid State | 14 | 12th June 2008 12:47 AM |
| Laptop 90W-120W? | di4kata | Power Supplies | 13 | 4th May 2006 01:22 PM |
| Output from Shiva with 120w? | nrgy | Subwoofers | 2 | 12th November 2004 12:18 PM |
| 120W Mosfet amp modules | Peter Daniel | Swap Meet | 7 | 14th November 2003 12:27 AM |
| Page generated in 0.11704 seconds (70.34% PHP - 29.66% MySQL) with 11 queries |
